| New Reply |
Need to get a bit more fuel for the furnace. |
Share Thread | Thread Tools |
| Feb7-12, 11:08 PM | #1 |
Well, we really don't need to, but it's nice to have around in case a family emergency requires us to be away from home a bit in the winter. When we bought this place 6 years ago, we bought a tank-full of #2 heating oil. I have supplanted that with 911 fuel-stabilizer a couple of times, and finally we are getting to the bottom of that tank. I ordered 100 gallons of oil today, and the woman at the fuel-supplier was asking some questions about usage. It's hard to explain to somebody in that business that you use very little oil, and a single tank of oil has already lasted 6 years... My youngest uncle is an HVAC guy, and he has encouraged me to run down the old oil and try to keep a minimal supply of fresh oil in the tank.
| Feb7-12, 11:09 PM | #2 |
| Feb8-12, 05:32 AM | #3 |
Recognitions:
... in Maine! (Woodstove, dude; woodstove) While on the topic of woodstoves and oil furnaces; we have burned less oil this winter than ever, thanks to an abundant wood pile, and a broken furnace. I've "fixed" it 3 times now, but the spark igniter keeps failing. Gap adjusted over and over, induction coil appears to work, all connections good... Looks like I'm gonna have to call in a perfeshunal who's gonna tell me my tank needs to be replaced. |
| Feb8-12, 06:43 AM | #4 |
Need to get a bit more fuel for the furnace.My solution is to go primarily woodburning. But then I'm partial to fireplaces. Really like them. Plenty of wood in Maine, and if I recall a picture of turbo's place, plenty of 'free' wood for a long time. |
| Feb8-12, 06:49 AM | #5 |
Mentor
Turbo primarily uses wood.
| Feb8-12, 07:26 AM | #6 |
| Feb8-12, 07:38 AM | #7 |
Yep! Primarily wood. It's already seasoned a minimum of a year and half before it ever comes in the house to the wood-box, so it burns very cleanly.
We're on track to burn ~3 cords this winter if this pattern of warm weather keeps up. In past years, we have burned ~4-5 cords a season. The stove burns so cleanly, I have never had to clean my chimney. Any tar and creosote build-up just flakes off with the heat of the next fire. About once a year, I go down cellar, open the clean-out door and scoop out a small pail-full of of black scale, then look up the chimney with a mirror. Clean as a whistle, with every tile and mortar-joint visible. |
| Feb8-12, 07:51 AM | #8 |
| Feb8-12, 08:38 AM | #9 |
Rhody...
| Feb8-12, 08:40 AM | #10 |
| Feb8-12, 09:12 AM | #11 |
We used wood for about ten years but I finally got sick of messing with it. We have such cheap hydroelectric power that the savings with wood are not significant. I have two+ cords for emergencies, but allowed another six cords of old growth [diseased tree] to rot up on the hill.
I keep thinking about going with a geothermal heat-pump system. |
| Feb8-12, 09:15 AM | #12 |
| Feb8-12, 06:18 PM | #13 |
Recognitions:
Just sometimes, as you are aware, you just don't feel like messing with the wood, just for a day. Well, not an option right now. I'll get it fixed in the spring, when Oil guys aren't charging arms and legs for dropping by. |
| Feb8-12, 11:07 PM | #14 |
Why was it so hard to explain what you were using the oil for? I'm sure the lady on the phone would be able to understand unless she doesn't speak english or something? Seems to me you should just call them back up and hope for a guy to answer the phone this time.
| Feb9-12, 12:17 AM | #15 |
I do want to keep my hot-air furnace in working condition, and fueled with oil that is relatively clean. There are times and potential situations in which having a furnace back-up might be nice, if not critical. My health is not the best, and it could be really important to keep the house from freezing up if my wife and I are not here during a cold spell. |
| New Reply |
| Thread Tools | |
Similar Threads for: Need to get a bit more fuel for the furnace.
| Fuel pressure change in closed fuel tank | General Engineering | 9 | ||
| Aircraft Fuel Booster Pump - Centrifugal & Immersed in Fuel | Mechanical Engineering | 1 | ||
| Fuel savings on a re-heat furnace. | Materials & Chemical Engineering | 0 | ||
| furnace device | Introductory Physics Homework | 3 | ||
| stiochiometric air-to-fuel ratio for heavy fuel oil | Engineering Systems & Design | 2 | ||
