How to calculate time for ticker tape to move from a point to another point?
  • Thread starter Thread starter Mphisto
    Point Time
The discussion revolves around calculating the time it takes for a ticker tape to move from one point to another, given that the ticker-tape timer produces dots at a rate of 50 per second. Participants explore the implications of the distance between these dots and how it relates to time and speed.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between the distance between dots and the time taken to cover that distance. Questions arise about how to account for varying distances and the implications of acceleration on the calculations.
Some participants have offered guidance on measuring distances and understanding the time per dot. There is recognition of the need to consider acceleration, and while some clarity has emerged, multiple interpretations regarding the relationship between distance, time, and speed are still being explored.
Participants note that the problem involves increasing acceleration, which complicates the relationship between speed and distance. There is also mention of using a ruler to measure distances on the ticker tape.
Mphisto
Question: How to calculate time for ticker tape to move from a point to another point?
"The ticker-tape timer consists of a steel strip which vibrates 50 times a second and makes 50 dots a second on a paper being pull through it."
the dots on the ticker tape are increasing in distance, how to count the time taken for it to move from a point to the other? I have no idea what to begin with...
Start with this:
The distance between dots (any 2 dots or more) corresponds to what? What does it mean to measure the distance between these dots?
If you have 50 dots per second, how many seconds does 1 dot correspond to?
DivisionByZro said:
Start with this:
1 dot correspond to 0.02 sec, but how do I calculate for those that are further apart from the constant ones ( constant distance between the dots)
Remember that the more dots you measure, the more precise your average measurement will be. Now, you know the time it takes for two dots to be drawn, if you measure the distance between any two dots, you know that it took 0.02s to cover that distance. What can you say about the speed of the tape? For the ones that seem further than others, calculate them in the same way.
Wouldn't the speed and distance be different for dots that are further away from each other? that would be 2 unknown variables which I don't know how to solve...
P.S. it is in an increasing acceleration
[STRIKE]Oooo, regardless how far dots are apart from each other, the time taken would still be 0.02s from a dot to the other? am i right?[/STRIKE]
EDIT: do we use a ruler to measure? on the ticker tape
Yes use a ruler, and yes if the dots are increasing in distance then there is an acceleration, you have to account for that.
How is acceleration linked to velocity? (In terms of formulas)
Yeah, i figured out how to do it :smile:
Thanks guys!
  • · Replies 18 ·
10K
10K
  • · Replies 53 ·
