Contraction of a static fluid due to cooling
The discussion focuses on modeling the contraction of a static fluid, specifically water glycol, in a hydraulic system due to cooling effects. As the fluid cools, it experiences contraction, leading to a decrease in pressure within a closed pipe. This pressure drop necessitates the injection of additional fluid to maintain system balance. Key concepts mentioned include thermal expansion and its coefficients, which are critical for understanding the dynamics of fluid contraction and pressure changes.
  • Understanding of thermal expansion principles
  • Familiarity with hydraulic systems and their components
  • Knowledge of fluid dynamics and pressure behavior in closed systems
  • Basic concepts of volumetric and linear coefficients of thermal expansion
  • Research the effects of thermal expansion on hydraulic systems
  • Study the volumetric coefficient of thermal expansion for various fluids
  • Explore literature on pressure dynamics in closed fluid systems
  • Investigate compensation mechanisms in hydraulic systems
Engineers, fluid dynamics researchers, and hydraulic system designers seeking to understand the effects of cooling on fluid contraction and pressure management in closed systems.
chaoticfarmin
Hi,
I'm trying to model a compensation device in a hydraulic system. Basically, I have a closed pipe that contains a body of liquid (water glycol) and as time elapses this fluid is subject to a cooling effect. This results in contraction and hence a pressure decrease which is subsequently compensated for by the injection of additional fluid.
What I'm struggling to understand are the exact dynamics of contraction and how this affects the pressure (for example, does a vacuum form etc.?).
If anybody can impart some pointers/direct me to some good literature then I would be extremely grateful!
Cheers if you can help.
  • · Replies 31 ·
  • · Replies 45 ·
  • · Replies 29 ·
  • · Replies 42 ·
  • · Replies 42 ·
12K
