@what pt. does y=e^(32x) have max curvature?
  • Context: Graduate
  • Thread starter Thread starter nobelsmoke
    Curvature Max
The discussion revolves around determining the point at which the curve defined by the equation y=e^(32x) has maximum curvature. Participants explore various methods and formulas related to curvature, including derivatives and critical points, while attempting to resolve discrepancies in their calculations.
  • One participant presents a method for finding maximum curvature using a specific formula for curvature, but notes that their initial calculations were incorrect.
  • Another participant provides the formula for curvature and derives the first and second derivatives of the function, leading to a complex expression for curvature.
  • A participant questions the differences in the curvature formulas presented and clarifies the placement of terms in the equations.
  • Corrections are made regarding the derivatives, with one participant acknowledging a mistake in their earlier response about the order of derivatives.
  • Several participants share their attempts and errors in calculations, seeking feedback and clarification on their work.
  • There is a suggestion that the grading program may expect a specific form of the answer, which could lead to confusion about the correctness of their results.
  • Another participant raises a question about the interpretation of logarithms in the grading system, suggesting it may affect the acceptance of their final answer.
Participants express uncertainty and disagreement regarding the correct application of curvature formulas and the interpretation of logarithmic expressions. Multiple competing views on the correct approach and potential errors remain unresolved.
Participants note limitations in their calculations and the need for clarity on the definitions used, particularly regarding logarithmic bases and the forms of their answers. There are unresolved mathematical steps and assumptions that may affect the final results.
nobelsmoke
Here is the question:
At what point does the curve y=e^(32x) have maximum curvature?
I have tried this method: http://www.math.washington.edu/~conroy/m126-general/exams/mt2SolMath126Win2006.pdf
Problem 4. Adapting for 32x rather than x
it seems to get a bit lengthier with 32x than with x
i got ( -log(2048)/64, 1/32sqrt(2) )
but this was incorrect .
It seems finding the critical number takes some manipulations.
Okay, the formula you quote is
[tex]\kappa(x)= \frac{|f''(x)|}{1+ (f'(x))^2)^{3/2}}[/tex]
You have [itex]f(x)= e^{32x}[/itex] so that [itex]f'(x)= 32e^{32x}[/itex] and [itex]f''= 1024e^{32x}[/itex] so
[tex]\kappa(x)= \frac{32e^{32x}}{(1+ 1048576e^{32x})^{3/2}}[/tex].
To find a maximum (or minimum) for that function, differentiate and set the derivative to 0:
[tex]\frac{1024e^{32x}(1+ 1048576e^{32x})^{3/2}- 50331648e^{32x}(1+ 1048576e^{32x}(33554432e^{32x})}{(1+ 1048576e^{32x})^3}= 0[/tex]
A fraction is 0 if and only if the numerator is equal to 0 so set the numerator equal to 0 and solve.
Firstly, HallsofIvy Thank you for responding.
The formula for k(x) you have written is different than the one I quoted. In mine, 1 is inside the parenthesis in the denominator, also raised to the power of (3/2).
Anyway, we know that abs(f''(x)) belongs in the numerator.
And,
abs(f''(x)) = 1024e^(32x)
So, how do we end up with simply 32e^(32x) in the numerator for k(x) ?
Oh, bother! Yes, you are right- I did reverse f' and f''. [itex]f'(x)= 32e^{32x}[/itex] and [itex]f''= 1024e^{32x}[/itex] so
[tex]\kappa= \frac{1024e^{32x}}{(1+ 1024e^{64x})^{3/2}}[/tex]
nobelsmoke said:
What point did you come to?
Here is a link to my two incorrect attempts:
http://i.imgur.com/DDKEO.png
Can you show your actual work? Our forum policy is not to provide students with answers. But if you show your work, we can probably spot where the error is.
Wait, never mind. I find that I agree with your 2nd answer given in Post #5. So the grading program may expect you to write it in a different (but equivalent) form.
Thank you for responding RedBelly98
Here's my work:
f'(x) = 32e^(32x)
f''(x) = 1024e^(32x)
k(x) = (1024e^(32x)) / [1+1024e^(64x)]^3/2
k'(x) =
(32768e^(32x) / (1024e^(64x)+1)^(3/2) - (100663296e^(96x)) / (1+1024e^(64x))^(5/2)
when k'(x) = 0 , x = - log(2048)/64
y = e^(32x)
y = e^ (-32log(2048)/64 )
y = e^ (-log(2048)/2)
y = 1 / (32sqrt(2))
The point is at ( -log(2048)/64, 1/32sqrt(2) ).
Somewhere I went wrong.
Ok, thank you. I will keep that in mind.
Perhaps if you expressed 2048 as (an integer)(another integer), then you could simplify the expression -log(2048)/64 and get it in a form that would be accepted.
Great Idea,
I'll post here after I submit my final attempt.
Another thought: are you sure the grading system interprets "log" to mean the natural log, and not the base-10 log?
  • · Replies 230 ·
22K
9K
  • · Replies 71 ·
14K
