Thread Closed
lockers
Share Thread Thread Tools
Dec23-04, 03:09 PM   #1
T@P
lockers
there are 100 lockers lined up in a row, and for some unknown reason they are unlocked. for a similarly unknown reason there are 100 students lined up outside the hallway containing the 100 lockers. the first student goes and opens all the lockers. the second then goes and closes every second. the third either opens or closes every third locker, (changes the "state" of it) for example, the 6th locker is closed when the 3rd guy comes to it, so he opens it. after all 100 students go by, what lockers are open/closed? please note i dont think that you should list out all 100 lockers and their state, there is a pattern.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Dec23-04, 03:53 PM   #2
The state of each locker is altered a number of times equal to the total number of factors of the locker number. So the lockers with numbers that have an even number of factors (including 1) are closed, and the lockers with numbers that have an odd number of factors are open. (Not counting just prime factors, counting all factors, and numbering the lockers from 1)
Dec27-04, 12:18 PM   #3
Recognitions:
Homework Helper Homework Help
Quote by Bartholomew
What do all numbers that have an odd number have in common? It's a pretty well-known property...1,4,9...?
Dec27-04, 12:53 PM   #4
lockers
That's cool!
Dec28-04, 12:24 PM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
What do all numbers that have an odd number of factors have in common?
Dec28-04, 02:27 PM   #6
Of course, that's what he meant. I'm no expert, but: First you get the prime factorization of the number. Each factor can be generated by choosing some number of each prime factor (a number from 0 to the power of that factor) and multiplying them all together. So the total number of factors is (a + 1) * (b + 1) * (c + 1) ... where a, b, c, ... are the exponents on 2, 3, 5, ... in the prime factorization. So for this product to be odd, all of a + 1, b + 1, c + 1, ... must be odd, so all of a, b, c, ... must be even, so the original number is a perfect square (and vice versa, if it's a perfect square then it has an odd number of factors).
Dec28-04, 04:51 PM   #7
Recognitions:
Nicely done. Yeah, Gokul I need to be more careful when I type/post.
Dec29-04, 02:04 PM   #8
Recognitions:
I'm no expert, but...
Me neither, but I believe that's how the experts do it too, but being experts they like to use fancy terms.
[tex]N = \Pi p_i ^{k_i} [/tex]
[tex] \tau (N) = \Pi (k_i + 1) [/tex]
[itex] \tau (N) [/itex], known simply as the tau function, is a multiplicative function that counts the number of divisors of a given number.
So, an "expert" might simply say that for [itex] \tau (N) [/itex] to be odd, all of [itex] k_i [/itex] must be even, or [itex] k_i = 2m_i [/itex]. Which gives [itex] N = \Pi p_i ^{2m_i} = (\Pi p_i ^{m_i} )^2 = M^2 [/itex].
Jan8-05, 02:35 PM   #9
Recognitions:
Is the answer 31? My physics teacher gave this problem as a bonus questions, so I made a C++ program to figure out all the perfect squares between 1 and 1000, and the program says the answer is 31.
I'll get an extra 10% on the next lab if I get this right, so it's kind of important that I get confirmation before Monday, January 10, 2005.
Jan8-05, 02:57 PM   #10
Recognitions:
Select to read. (I'm editing to put into spoiler text because that's what other people did.)
Yes, presuming your question was for 1000 lockers (and students) and they all started off closed and they asked which ones were open after the process was over. (The original post was only for 100 lockers.) You didn't really need the progam, though: like the lay version of what Gokul said, any number with an odd number of factors will end up open, meaning all of the perfect square numbered doors will end up open (which you already know). So all you had to do was look at the square root of 1000 and truncate the decimal places (round down to the nearest integer) and that would be the answer (31).
Jan8-05, 03:08 PM   #11
Recognitions:
Quote by jamesrc
Thanks for the confirmation. When I get some free time, I will look closer at Goku's stuff to see what it means or at least how he got that.
*edit
that spoiler text is still very visible in a quote box
Jan8-05, 04:52 PM   #12
Recognitions:
Quote by ShawnD
I suggest you read Bart's explanation. It's in a form that's a lot simpler to absorb.
Thread Closed
Thread Tools
Similar Threads for: lockers
Thread Forum Replies
tricky lockers... Brain Teasers 12
