| New Reply |
Nullspaces of a Matrix |
Share Thread |
| Feb11-12, 05:50 PM | #1 |
Given an mxn matrix M, prove that Null((M^T)(M)) = Null(M) Where M^T is the transpose of the matrix M. 3. The attempt at a solution I was able to get the first part (Null(M) is a subset of Null((M^T)(M))), but I'm just having trouble proving the other way around. I pick any vector in Null((M^T)(M)), but unsure of what to do after that. |
| Feb12-12, 12:57 PM | #2 |
The standard way to prove that to sets, A and B, say, are equal is to prove A is a subset of B then prove that B is a subset of A. And you prove A is a subset of B by starting "if x is in A" and then use the properties of A and B to conclude "x is in B".
Here, the two sets are Null(M) and Null(M^T(M)). If x is in Null(M) then M(x)= 0. It then follows immediately that M^T(Mx)= M^T(0)= 0. That's the easy way. If x is in Null(M^T(M)) then M^T(M(x))= 0. Obviously, if M(x)= 0 we are done. What can you say about non-zero x such that M^t(x)= 0? |
| New Reply |
Similar discussions for: Nullspaces of a Matrix
| NxN-complex matrix, identified 2Nx2N-real matrix, determinant | Linear & Abstract Algebra | 2 | ||
| real matrix -- eigenvector matrix R -- diagonal eigenvalue matrix L | Programming & Comp Sci | 0 | ||
| Intersection of nullspaces | Linear & Abstract Algebra | 2 | ||
| Coding Covariance Matrix (differential Riccati matrix eqn) of the Kalman-Bucy Filter | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Prove that Hermitian/Skew Herm/Unitary Matrix is a Normal Matrix | Calculus & Beyond Homework | 2 | ||
