New Reply
Torsion Test Equipment
Share Thread Thread Tools
Feb12-12, 01:22 AM   #1
Hello,
I'm a student of mechanical engineer and currently doing a project on "fabricating a torsion test equipment".
I'm just wondering about my torque calculations.
My design is quite simple, consists of:
- angle iron (frame)
- torque angle gauge (to measure angle of twist)
- 2x 1/2" drill chucks (one fixed at the other end and one is rotating with a torque wrench as an applying force)
Now, the question is, how do i calculate the "maximum torque" or force (at the fixed one) it can holds? My specimen is 10mm diameter with 100mm of length.
Regards,
Ren
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb12-12, 05:59 PM   #2
If the torque wrench that you use to apply the load has a maximum reading indicator, that will give you the data you seek right there.
Feb12-12, 10:37 PM   #3
Quote by OldEngr63 View Post
What i understood from your reply, when the specimen breaks, i will just record the reading from the torque wrench (Nm)?
If that's what you meant, my question is still unanswered, i am finding the maximum force (torque) the drill chuck can grip the specimen until it slips.
Feb13-12, 09:29 AM   #4
If the drill chuck slips, then your fixture is inadequate. The whole point of the chuck is to not slip but rather to transfer twist to the test item.
Feb13-12, 12:04 PM   #5
Engineering 2012
Recognitions:
Gold Membership Gold Member
file three flats on end of your specimen to mate with the chuck's teeth?
for all we know your specimen is made of material too hard to grip or your chuck might be worn out.
one experiment is worth a thousand expert opinions.
New Reply
Thread Tools
Similar Threads for: Torsion Test Equipment
Thread Forum Replies
Design and Construction of a Torsion Testing Equipment Engineering Systems & Design 0
Test Equipment Electrical Engineering 1
Test equipment for actuator frequency response Mechanical Engineering 0
Any good books on designing test equipment? Electrical Engineering 5
Test Equipment Computing & Technology 11
