Potential energy of a spring and transverse motion
The discussion revolves around the potential energy of a spring and its behavior under transverse motion. Participants are exploring the relationship between the stretched distance of a spring and the forces involved in its extension.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to relate the stretched distance of the spring to the applied force and the geometry of the situation. There is a focus on parameterizing the stretch as a function of distance moved and understanding the work done in different scenarios.
The discussion is active, with participants providing insights and questioning assumptions about the work done on the spring. Some guidance has been offered regarding the geometric interpretation of the problem, but there is no explicit consensus on the relationships being explored.
There is mention of specific parameters and equations related to the problem, but some participants express confusion about the assumptions regarding the work done and the relationships between the variables involved.
jskro
L = Stretched distance
L0 = Unstretched distance
W = 1/2kL2
In attempting to help a friend with this problem, having taken this same physics class under a different professor, i was completely stumped by this problem. I know that Fx = kL, but i can't make any headway on figuring out the part of the problem that involves the transverse of the spring that leads to a distance pulled of xm with the same applied force that stretches the spring the same distance. Is there something easy that I'm missing?
For a) you need to parameterise the amount it has stretched in fig b as a function of x. Geometrically think of take the stretched spring in b, and rotating it back to vertical. Then consider the relation between the extrat height L(x) and the distance it was moved x. After this I presume you are okay?
So basically, because the work done in each of the two scenarios is the same?
Fx*xm = 1/2kL^2
xm = (kL^2)/(2Fx)
You do not know that the work done is the same, you just follow the prescribed method to determine it. I'm getting a bit confused by what you mean by
Fx*xm = 1/2kL^2
xm = (kL^2)/(2Fx)
What do you think is the answer to question a), Ie L(x)=? once you know this, then you can consider the force needed to extend the spring by L(x), and that is the answer to question b).
By rotating b back vertically, the distance it was pulled is xm
L(x) = xm
Exactly, so now you can find the magnitude of the force easily enough, the rest follows from this.
  • · Replies 20 ·
