System of linear congruences Help, please
  • Context: Undergrad
  • Thread starter Thread starter MathExpert
    Linear System
This discussion focuses on solving a system of linear congruences using the Chinese Remainder Theorem (CRT) and the Extended Euclidean Algorithm. The system consists of three equations: 5x ≡ 200 (mod 251), 11x ≡ 192 (mod 401), and 3x ≡ -151 (mod 907). The solution process involves finding the inverses of the coefficients using the Extended Euclidean Algorithm, simplifying the equations, and applying CRT to arrive at the final solution of x ≡ 5 (mod 907).
  • Understanding of modular arithmetic
  • Familiarity with the Chinese Remainder Theorem
  • Knowledge of the Extended Euclidean Algorithm
  • Basic algebraic manipulation skills
  • Study the Chinese Remainder Theorem in depth
  • Practice the Extended Euclidean Algorithm with various examples
  • Explore applications of linear congruences in cryptography
  • Learn about pairwise coprime integers and their significance in modular systems
Mathematicians, computer scientists, and students studying number theory or cryptography who are interested in solving modular equations and understanding linear congruences.
MathExpert
5x == 200 (mod 251)
11x == 192 (mod 401)
3x == -151 (mod 907)
first find the inverses of 5, 11 and 3 modulo 251, 401, 907 resp. to make it easier to solve. do this using eulcid's algorthim if you do'nt see what the inverse are straigh away. hint 5*50=250, and 3*302=906.
then use the chinese remainder theorem on the first two to reduce to two equivalences, then repeat.
A system of linear congruences is a set of equations that involve modular arithmetic, where the unknown variable is congruent to a given value modulo a certain number. In this case, the system involves three equations with the unknown variable x, and each equation is congruent to a different value modulo a different number.
To solve this system, we can use the Chinese Remainder Theorem, which states that if the moduli (in this case, 251, 401, and 907) are pairwise coprime (meaning they have no common factors), then there exists a unique solution to the system.
First, we can simplify each equation by dividing both sides by the coefficient of x. This will give us the following system:
x == 40 (mod 251)
x == 192 (mod 401)
x == 252 (mod 907)
Next, we can use the Extended Euclidean Algorithm to find the inverse of each modulus. This will give us the following values:
251^-1 = 4 (mod 401)
401^-1 = 201 (mod 251)
907^-1 = 253 (mod 251)
Using these values, we can now apply the Chinese Remainder Theorem to solve the system. The solution will be given by the following formula:
x = (40*401*201 + 192*251*4 + 252*907*253) (mod 251*401*907)
Simplifying this, we get:
x = 5 (mod 907)
Therefore, the solution to this system of linear congruences is x = 5 (mod 907). I hope this helps!
  • · Replies 22 ·
  • · Replies 23 ·
  • · Replies 26 ·
