Find Angular Position of Particle in Vertical Circle Motion
The problem involves a particle moving in a vertical circle of radius R, with an initial speed at the lowest point related to the minimum speed required to maintain contact with the track. Participants are tasked with finding the angular position at which the particle loses contact with the track.
  • Mixed
  • Some participants discuss using conservation of energy to relate the speeds and heights at different points in the motion.
  • Others question the assumptions regarding the minimum speed required to maintain contact with the track, suggesting that the speed at which the particle loses contact is not zero.
  • There are discussions about the centripetal acceleration at the top of the track and how it relates to the particle's motion at point P.
  • Participants explore the forces acting on the particle and how they affect the motion and contact with the track.
The discussion is ongoing, with various interpretations and approaches being explored. Some participants have provided guidance on considering forces and the conditions for maintaining contact, while others express confusion about the assumptions made in the problem. There is no explicit consensus on the correct approach or solution yet.
Participants are grappling with the implications of energy conservation and the forces acting on the particle, particularly in relation to the minimum speed required for contact. The problem is framed within the constraints of a homework assignment, which may limit the information available for discussion.
Clari
A particle m is moving in a vertical circle of radius R inside a track. There is no friction. When m is at its lowest position, its speed is v0.
Suppose v0 is 0.775 vmin [ vmin = root(5gR) ]. The particle will move up the track to some point at P at which it will lose contact with the track and travel along a path roughly like a line connected to the centre of the circle. Find the angular position theta of point P.
I solved the question by conservation of energy. energy at the bottom = 1/2 mv^2...1/2m (0.775)(5gR)
energy at the top, when the particle is momentarily at rest...mgh...
1/2m(0.775^2)(5gR) = mgh
h= 1/2(0.775^2)(5R)
h is less than 2R, so h-R will give the height of a triangle form , where theta is the angle in the triangle...
(h-R) = R sin(theta)...and I get theta = 30 degrees...but the answer is 19.5 degrees...what's wrong with my steps? please tell me...
You are assuming that the mass loses contact with the track when its speed is zero. Not so. There is a minimum speed required to maintain contact; find it by considering the forces on the particle and Newton's 2nd law.
h= 1/2(0.775^2)(5R)
I'm in the middle of solving this problem. I'm just wondering, the minimum centripetal acceleration at the top of the track is 6g. Shouldn't it be 5g as indicated by v^2(min)/R? It would make more sense considering it's
v^2(min)/R... Which is why, i don't think the answer should be 19.5 degrees.
Hello Doc AI...I get the minimum speed to maintain contact as v^2 = gr...Now I set the equation as 1/2 m(0.775^2)(5gR) = 1/2m v_min^2 + mgh...but h = 1.0015625 R...so I don't get a sensible theta...or am I misunderstanding something?
Hello apchemstudent....yes, you're right, the minimum centripetal acceleration at the top is v^2 = 5gR...but now, the particle is not at the top of the circle, because it has a smaller speed, that's why it can only moves to some point P...
However though, you can use the ratio of the min Centripetal acceleration of the track and the min centripetal acceleration of the particle (if it were traveling in its own circle) to figure out theta...
You're so close Clari. Keep going with that idea you and Doc Al have been toying with. Your problem lies with the minimum velocity it must have to remain on the track. You said it was: v^2 = gr. I'm going to tell you that this is not quite right. Remember how the two forces you are comparing are oriented. You need to make a slight modification before this is right. Can you tell me what you have to do?
I'll show you what a i meant by the 19.5 degrees not making any sense.
Ao = Vo^2/R = 29.43...
However, this is at the bottom of the track. To figure out the min (I'll just called centripetal acceleration now as A(c)) A(c), we'll need to subtract 29.43 - 9.8 = 19.63...
We know the min A(c) for the track which is 5g so:
sin(theta) = 19.63/5g
theta = 23.6 degrees
However for the 19.5 degrees the min A(c) for the track will have to be 6g, which is incorrect, for the A(c) min is stated as 5g. You can try that out yourself. Adding on the extra g does not make sense for the min A(c) for the track. Can anyone explain why it is done this way?
umm...Thank you for all of ur help...I give up the use of conservation of energy in this problem...because I really don't know what I need to do...>_<...instead, I consider the forces acting onthis particle...mg/sin theta - N = mv^2 / r...for N is the normal reaction force acting on the particle...when it is 0, the particle will falls off the track...so mg/sin theta = mv^2 /r...sin theta = gr / 0.775^2 * 5gr...theta = 19.5 degrees...^-^
Good job! The thing you forgot when you were finding the minimum velocity was the sin(theta), it should have been: v^2*sin(theta) = gr. Well, you found a more direct approach, but either way would have worked.
Actually, I'm abit confused about the answer as well. The way I see it, the centripetal force is always changing (decreasing) because of gravity. But your solution is assuming that is remains constant. Because you are saying, at some instant, the force of gravity will completely counter the centripetal force which will cause the particle to fall off. But you don't know what the centripetal force at that point is because it is always changing. I think I sort of see apchemstudents point. Can anyone reconcile this for us?
Sorry, but this answer makes no sense to me. For one thing, the radial force on the particle at point P is [itex]mg cos\theta[/itex] (or [itex]mg sin\theta[/itex], depending on how the angle is defined). It's not [itex]mg/ sin\theta[/itex]. Secondly, the radial acceleration ([itex]v^2/R[/itex]) depends on the speed at point P (call it [itex]v_{min}[/itex]), not the speed at the bottom ([itex]v_0[/itex]).
To solve this you'll need to use both conservation of energy and Newton's 2nd law. Let's call the angle that the particle leaves the track [itex]\theta[/itex] (measured from vertical). The radial forces on the particle at that moment are [itex]mg cos\theta[/itex], so [itex]mg cos\theta = mv_{min}^2/R[/itex].
Now apply conservation of energy. At the bottom, there is KE = [itex]mv_0^2/2[/itex]. At the point P, there is PE ([itex]mgR(1+cos\theta)[/itex]) and KE ([itex]mv_{min}^2/2 = mgR cos\theta /2[/itex]). Write down the equation for conservation of energy and solve for [itex]\theta[/itex].
Using that idea you get the same answer of 19.5 degrees. That is where my confusion is. Why does her idea work?
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 32 ·
