Solve Eigen Values/Vectors of Matrix w/ Repeated Eigenvalues
  • Thread starter Thread starter Number2Pencil
The discussion revolves around finding the eigenvalues and eigenvectors of a specific 6x6 matrix that contains repeated eigenvalues. The original poster outlines their attempts to derive the eigenvalues and subsequently the eigenvectors, noting difficulties encountered during the process.
  • The original poster attempts to find eigenvalues by calculating the determinant of the matrix and setting it to zero. They express confusion when trying to derive eigenvectors, particularly with the repeated eigenvalue of 2, leading to a system of equations that seems unsolvable.
  • Some participants suggest a block matrix approach to simplify the problem, questioning the implications of the matrix's structure on the solution process.
  • Further questions arise regarding the nature of the matrices involved, the method of solving simultaneous equations, and the challenges posed by the freedom of choice in variable assignments.
  • Participants discuss the implications of non-invertible matrices in the context of eigenvalues and the expected nature of eigenvector solutions.
The discussion is ongoing, with participants exploring various methods to tackle the problem. Some guidance has been offered regarding the block structure of the matrix and the simplification it provides. However, there is no explicit consensus on a single approach, as multiple interpretations and methods are being considered.
Participants note the complexity of the problem due to the repeated eigenvalues and the resulting freedom in choosing variable values, which complicates finding a unique solution. The original poster also mentions using MATLAB for verification, indicating the potential for computational assistance in solving the problem.
Number2Pencil
Find the eigen values/eigen vectors of
[tex] \left[<br /> \begin{array}{cc}<br /> 3&-1&1&1&0&0\\<br /> 1&1&-1&-1&0&0\\<br /> 0&0&2&0&1&1\\<br /> 0&0&0&2&-1&-1\\<br /> 0&0&0&0&1&1\\<br /> 0&0&0&0&1&1\\<br /> \end{array}<br /> \right][/tex]
The lambda equation is:
[tex] A - \lambda I =<br /> \left[<br /> \begin{array}{cc}<br /> 3 - \lambda&-1&1&1&0&0\\<br /> 1&1 - \lambda&-1&-1&0&0\\<br /> 0&0&2 - \lambda&0&1&1\\<br /> 0&0&0&2 - \lambda&-1&-1\\<br /> 0&0&0&0&1 - \lambda&1\\<br /> 0&0&0&0&1&1 - \lambda\\<br /> \end{array}<br /> \right]<br /> [/tex]
Finding the determinant yields:
[tex] -32 \lambda + 80\lambda^2 - 80\lambda^3 + 40\lambda^4 - 10\lambda^5 + \lambda^6[/tex]
Setting equal to zero and factoring gives the eigen values:
[tex] \lambda = <br /> \left[<br /> \begin{array}{cc}<br /> 0\\<br /> 2\\<br /> 2\\<br /> 2\\<br /> 2\\<br /> 2\\<br /> \end{array}<br /> \right][/tex]
Plugging in lambda = 2 into the lambda equation gives:
[tex] \left[<br /> \begin{array}{cc}<br /> 1&-1&1&1&0&0\\<br /> 1&-1&-1&-1&0&0\\<br /> 0&0&0&0&1&1\\<br /> 0&0&0&0&-1&-1\\<br /> 0&0&0&0&-1&1\\<br /> 0&0&0&0&1&-1\\<br /> \end{array}<br /> \right][/tex]
The columns help for the simultaneous equations:
The bottom four rows reveal that X5, X6 = 0
Adding the first two rows together gives:
2X1 - 2X2 = 0
or
X1 = X2, So I choose X1 = X2 = 1, since the eigen vector must be a non-zero vector.
X3 and X4 cancel out so I choose them to = 0.
Since the eigen values repeat, I have to use the previous eigen vector as the answer to the simultaneous equations:
Summing the top two rows together:
2X1 - 2X2 = 2
or
X1 = 1 + X2. Everything else is still zero, choose X2 = 0, X1 = 1
Recursively using the previous eigen vector:
2 equations, 4 unknowns, choose X2 = 0, X4 = 0, top two equations become:
X1 + X3 = 1
X1 - X3 = 0
X1 and X3 = 1/2
This is where the trouble comes into play:
3rd equation : X5 + X6 = 1/2
4th equation: -X5 - X6 = 0
which cannot be solved...
This keeps happening over and over. I used MATLAB to verify that the eigen values and vectors could be found...but I cannot solve this through.
Any suggestions?
Your problem is in the block form
[itex][\begin{array}{cc}A&B\\0&C\end{array}][\begin{array}{c}x_1\\x_2\end{array}]=\lambda[\begin{array}{c}x_1\\x_2\end{array}][/itex]
which is
[itex]Ax_1+Bx_2=\lambda x_1[/itex]
[itex]Cx_2=\lambda x_2[/itex]
which you can solve easier because they are 3x3
A few more questions (forgive my lacking linear algebra skills)
1) You say that the problem was in a special form...why does this method present itself due to the form? Does it not apply if the lower-left 3x3 was not equal to zero?
2) are x1 and x2 both going to be 3x3 matrices, and concatenated together into a 3x6 will be the eigen vectors?
3) In terms of solving for x1 and x2, is this just simultaneous matrix equations, so perform the usual simultaneous-equation solving skills (with inverse matrices instead of division)?
4) Was it just very difficult (or impossible) to solve it the way I had described, due to the fact that I get too much freedom to choose many of the values, and end up getting stuck during the process if I'm not very strategic?
1) The lower-left block being 0 makes the second equation that I gave simpler, otherwise the two equations will be coupled, and not easy to solve by hand. It is just a trick that you play to make a homework (not real life) problem simpler.
2) x1 and x2 are both 3x1 vectors, they concatenate to a 6x1 vector that is the eigenvector, there are multiple solutions, but I recommend that you treat them as vectors not matrices, and find out all the vectors that satisfy the equations.
3) The second equation is a 3x3 eigenvalue problem, solve as you did for the 6x6 problem, only much simpler (by hand); then sub into the first equation and solve as a linear system (also 3x3, try to find all the solutions, whatever way you prefer)
4) Honestly I didn't read your description, but eigenvalue problems are hard problems, usually handled by computers, any general form beyond 6x6 is probably too much for a human :)(unless it has special structures, such as convolution matrix, etc. )
Alright, well here's how far I got:
[tex] |C - \lambda I| = (2-\lambda)(-2\lambda + \lambda^2)[/tex]
So the eigen values for the C Matrix are 2, 2, and 0.
I won't show the exact steps, but my eigen vectors (x2) for C are:
[tex] \left[<br /> \begin{array}{cc}<br /> 0\\<br /> 1\\<br /> -1\\<br /> \end{array}<br /> \right][/tex]
[tex] \left[<br /> \begin{array}{cc}<br /> 1\\<br /> 0\\<br /> 0\\<br /> \end{array}<br /> \right][/tex]
[tex] \left[<br /> \begin{array}{cc}<br /> 0\\<br /> -\frac{1}{2}\\<br /> -\frac{1}{2}\\<br /> \end{array}<br /> \right][/tex]
Solving the first equation for x1:
[tex] x1 = (A-\lambda I)^{-1} (-B x2)[/tex]
but now the problem is that when I plug in 2 for lambda, I end up with a matrix that I cannot take the inverse of.
Any suggestions on moving forward??
I think you're a bit confused. The whole point of eigenvalues is that those are the values which, when you plug in for lambda, you get a non-invertible matrix. Let's look at a smaller example to see how to find the corresponding eigenvector. Given the matrix
[tex]\left( \begin{array}{cc}1&1\\0&0\end{array} \right)[/tex]
You can check that it has eigenvalues of 0 and 1. Let's find the eigenvector corresponding to 1:
[tex]\left( \begin{array}{cc}1&1\\0&0\end{array} \right) \left( \begin{array}{cc} x\\ y \end{array} \right) = 1*\left( \begin{array}{cc} x\\ y \end{array} \right)[/tex]
This gives us two equations: x+y=x and 0+0=0. So the "solution" to this system of equations is y=0 and x can be anything. In general you won't get a unique solution, because if v is an eigenvector, you can scale v to get another eigenvector. So you expect to get a one dimensional set of solutions
Okay. I see. You're right I was confused about the eigen-vectors creating a non-invertible matrix.
The example you described was the original method I was trying to do, but got stuck with impossible to solve system of equations (on the 4th repeated eigen-value "plug-in", see first post)
Following sunjin's suggestion of partitioning the matrix and creating linear system to solve, I got stuck on not being able to take the inverse (because of what you just told me about eigen-vectors).
Sooooo...is there a different way to solve that linear system..is there a different way to do the original approach of simultaneous equations...or is there another method altogether??
If you row-reduce your matrix a bit more, you get
\begin{bmatrix}
1&-1&0&0&0&0\\
0&0&1&1&0&0\\
0&0&0&0&1&0\\
0&0&0&0&0&1\\
0&0&0&0&0&0\\
0&0&0&0&0&0\\
\end{bmatrix} which corresponds to the four equations
\begin{align*}
x_1 - x_2 &= 0 \\
x_3+x_4 &= 0 \\
x_5 = 0 \\
x_6 = 0
\end{align*} You analyzed the first, third, and fourth equations already and found one eigenvector from this system, but there's a second one. From the first eigenvector, you had (1,1,0,0,0,0), (1,0,0,0,0,0), and (1/2,0,1/2,0,0,0). The fact you couldn't find a solution using the last vector in the chain means you've reached the end. Now you have to find a new chain starting with the second eigenvector.
Okay, I continued forward by doing the reduced-row echelon form, and now I am verifying my answers.
When I multiply the original A matrix by the eigenvector (1,0,0,0,0,0), I get an answer of (3,1,0,0,0,0)...Shouldn't the answer be a scalar multiple of the eigenvector? Does this mean I've made a mistake?
The matrix A doesn't have five linearly independent eigenvectors corresponding to the eigenvalue 2; it has only two, which you can find by solving the original system (A-λI)x=0.
The vector (1,0,0,0,0,0) is a generalized eigenvector of A. You found it by solving (A-λI)x = (1,1,0,0,0,0)T so you have Ax = (1,1,0,0,0,0)T + λx = (3,1,0,0,0,0)T.
Great! So that means everything is gravy now!
Thanks all, this has REALLY given me a lot of insight on some of these concepts. :)
