To which extent cathode rays can be considered as current in a wire
The discussion revolves around the nature of cathode rays and their comparison to electric current in a wire. Participants explore the implications of cathode rays producing magnetic fields, the effects of relativity on forces acting on charged particles, and the differences between cathode rays and conventional current in terms of charge distribution and behavior in external fields.
  • One participant questions whether a magnetic field exists around a cathode ray tube and if it can influence nearby charged particles through Lorentz force, citing Maxwell's equations.
  • Another participant asserts that while cathode rays can be considered a current, they differ from a current in a wire due to their susceptibility to external fields.
  • A participant mentions the use of devices like Integrated Charge Transformers in accelerators to measure charge, suggesting similarities in behavior between cathode rays and wire currents.
  • Some participants challenge the idea that magnetic and electric forces balance due to length contraction, arguing that Maxwell's equations apply in a stationary frame and questioning the context of length contraction.
  • There is a discussion about the nature of length contraction and its relevance to the forces acting on cathode rays, with one participant expressing confusion about the application of the concept in this context.
  • One participant highlights a key difference between cathode rays and wire currents, noting that cathode rays are strongly charged while wire currents are electrically neutral.
Participants express differing views on the implications of relativity and the behavior of forces in relation to cathode rays and wire currents. There is no consensus on the interpretation of length contraction or the balance of forces, indicating ongoing debate and uncertainty.
Participants reference Maxwell's equations and the behavior of electric and magnetic fields in different inertial frames, but there are unresolved assumptions regarding the application of these concepts to the discussion of cathode rays.
universal_101
I want to know if there is magnetic field around a cathode ray tube. That is, does magnetic compass deflect when brought close to a CRT ? If so, can this magnetic field (produced by cathode rays) be used to have Lorentz force on a moving charge particle ?
Presently, what I think is,
Maxwell's equation, [itex]c^{2}\nabla \times B = \frac{j}{\epsilon_{o}} + \frac{\partial E}{\partial t}[/itex]
Demands the need of Magnetic field for cathode rays, and the Lorentz force then should put some force on the nearby moving charge. But, due to relativity this magnetic force is balanced by extra electric force due length contraction.
Is that so ?
A cathode ray is a current, but it isn't a current in a wire. The current can do all the things you would expect of a current in EM, including producing magnetic fields.
The only thing is that if there are any external fields it will pretty easily re-shape the current, that is the big difference from a current in a wire which tends to stay in the shape of the wire.
Note that devices such as an Intergrated Charge Transformer are often used in accelerators to quantify the amount of charge moving in an accelerator beampipe. This is nothing more than a coil of wire to pick up the magnetic field from the moving charges.
So the properties are practically similar.
Zz.
The first point has already been answered. The remaining point:
universal_101 said:
[..] due to relativity this magnetic force is balanced by extra electric force due length contraction.
Is that so ?
I don't think so: Maxwell's description is supposed to be valid in the "stationary" system to which you refer. "length contraction" suggests the use of another inertial system that is in motion relative to your "stationary" system, but to which you not refer.
The frame in which length contracts is the one in which there should be magnetic force due to motion of the charge particles of cathode rays.
Zz.
Thanks, and for using the great example.
I would not know what length would contract: in your description I discern no object of fixed length on which that concept can be applied.
And independent of such considerations, the magnetic force and electric force are already given by the equations of Maxwell.
PS. concerning the question in the title: an important difference is that a cathode ray is strongly charged while a current in a wire is electrically neutral.
  • · Replies 48 ·
  • · Replies 28 ·
  • · Replies 61 ·
  • · Replies 20 ·
