Crystal Structure: Properties of Materials Depend on Structure
The discussion revolves around how various properties of materials are influenced by their crystal structures, such as face-centered cubic (f.c.c.), body-centered cubic (b.c.c.), and close-packed hexagonal (cph) arrangements. Participants explore the implications of crystal structure on thermophysical, mechanical, electronic, and magnetic properties, among others.
  • Some participants suggest that density is one of the properties dependent on crystal structure.
  • It is proposed that nearly all thermophysical and mechanical properties are influenced by crystal structure, with varying degrees of impact.
  • Interatomic spacing and atomic attraction are noted as factors affecting thermal conductivity and strength.
  • Participants mention that cubic structures exhibit isotropy due to symmetry, while elongated crystals show anisotropic properties.
  • Texture in hexagonal close-packed metals, such as zirconium, is discussed in relation to grain orientation and its effects on material properties.
  • Ductility is linked to the presence of slip planes, with specific slip planes associated with f.c.c. and b.c.c. structures affecting plastic flow characteristics.
  • Hardness is described as inversely related to ductility, with trends in tensile strength and toughness also connected to crystal structure, though influenced by other factors like microstructure and alloying.
  • Thermodynamic, electronic, and magnetic properties are mentioned as being related to crystal structure, with specific examples provided, such as the role of Cu-O planes in superconductivity and the influence of bond angles in manganites on magnetoresistance.
Participants express a range of views on the extent to which properties depend on crystal structure, with no consensus reached on specific properties or the overall impact of structure on material behavior.
Some claims depend on specific definitions of properties and may involve unresolved assumptions about the nature of crystal structures and their interactions with various material characteristics.
mecheng
Which properties of materials depend on the crystal structure (f.c.c., b.c.c. cph etc...) of materials?
mecheng,
How about density? :-)
Probably all thermophysical and mechanical properties depend to some degree (some more so than others) on crystal structure (morphology), but then each element which is solid has a preferred crystal structure.
Interatomic spacing, as well as the inherent attraction between the atoms, affects properties like thermal conductivity and strength.
Cubic structures are more isotropic due to symmetry. Crystals which are elongated in one or two of three directions exhibit anisotropies in their properties, i.e. the properties have a directional dependence.
Hexagonal close-packed metals (e.g. Zr) have a property called 'texture' which relates to the fraction of grains with a particular orientation of the basal poles, or c-axis (normal to the basal plane) in a poly-crystalline phase.
Most metals are found in a poly-crystalline as opposed to single-crystal structure. And within either configuration, some dislocations or holes in the lattice may occur. These too have important implications with respect to properties.
Virtually all of them do.
Ductility is clearly related to the existence of slip planes. The FCC structure has slip planes along (111) directions, while the BCC crystal's slip planes are the (110) family. This difference is instrumental in determining the plastic flow characteristics of the material. As a result, Cu, Ag, Au (all FCC metals) are extremely ductile, while Fe, Ni (BCC) are not. Hardness is inversely related to ductility and so hardness trends follow likewise. Tensile strength and toughness are also related to crystal structure, but other factors (microstructure, heat treatment, alloying) often dominate.
Also, thermodynamic, electronic and magnetic properties are related to crystal structure.
In the High Tc Cuprites, the Cu-O planes are vital to the incidence of superconductivity. In CMR manganites, the O-Mn-O bond angle affects the MR ratio. In aluminate-based long afterglow phosphors, there is a strong correlation between the lattice parameter and the wavelength of emitted light. Mobility of semiconductors, conductivity of diamond, magnetic anisotropy in transition metal-rare Earth intermetallics, etc. are all heavily dependent on the crystal structure.
