Understanding the Definition of an Ordered Pair
  • Context: Graduate
  • Thread starter Thread starter Perion
    Definition Pair
The discussion centers around the definition of an ordered pair in set theory, specifically the representation of an ordered pair (x,y) as the set {{x},{x,y}}. Participants explore the implications of this definition, particularly in proving the equivalence (x,y) = (u,v) if and only if x=u and y=v. The scope includes formal proofs, set theory, and logical structuring in mathematics.
  • One participant expresses confusion about why {{x},{x,y}} defines an ordered pair and seeks help with proving the equivalence of ordered pairs.
  • Another participant outlines a method for proving the equality of sets based on the definition provided, noting that if {{x},{x,y}} = {{u},{u,v}}, then either {x} = {u} and {x,y} = {u,v} or vice versa, but the latter cannot hold due to the nature of finite sets.
  • Some participants emphasize the importance of distinguishing between x and y to maintain the order in (x,y) versus (y,x).
  • There is a discussion about the features of the definition of ordered pairs, highlighting that it allows for mathematical operations without introducing new objects outside of set theory.
  • One participant questions the logical structure required for proving biconditional statements and discusses different approaches to presenting proofs.
  • A later reply points out a potential oversight in assuming x and y are distinct, suggesting that if x=y=u=v, the proof still holds.
  • Another participant clarifies the relationship between the Cartesian product and the definition of ordered pairs, indicating that elements of AxB can be represented as {x,{x,y}}.
Participants express various viewpoints on the definition and implications of ordered pairs, with some agreeing on the validity of the definition while others raise questions or challenge assumptions. The discussion remains unresolved regarding the nuances of the proof and the implications of equality in sets.
Some participants note limitations in their understanding of the definition of ordered pairs and the logical structuring of proofs, indicating that there may be missing assumptions or dependencies on definitions that are not fully explored.
This discussion may be useful for individuals studying set theory, formal proofs, or those interested in the foundational aspects of mathematical definitions and logic.
Perion
This should be so easy but I'm having trouble understanding why {{x},{x,y}} defines an ordered pair (x,y). I'm trying to work through the following problem from the Zakon Series pdf textbook:
Code:
If (x,y) denotes the set {{x},{x,y}} [B]prove that, for any x, y, u, v,
we have (x,y) = (u,v) iff x=u and y=v[/B]. Treat this as a definition of an
ordered pair.
[Hint: Consider separately the two cases (x equals y) and
(x not equal to y), noting that {x,x}={x}]
I'm just learning to do formal proofs so not sure about where to start. Since it's an iff equivalence I assume that I need to show that
1. if (x,y)=(u,v) then x=u and y=v
AND then also show that
2. if x=u and y=v then (x,y)=(u,v).
Is this the correct overall approach for proving the iff biconditional?
I'm OK with #2 since it's trivial to show that {{x},{x,y}}={{u},{u,v}} for x=u and y=v.
#1 also seems pretty simple when x=y but I'm not sure how to go about it for the case when x is not equal to y. Can you help me with this please.
Thank you,
Perion
[This isn't homework - I'm studying free math e-books on my own.]
If {{x},{x,y}} {{u},{u,v}} them by the definition of equality of sets either
{x}={u} and {x,y}={u,v} OR {x}={u,v} and {x,y}={u}
obviously the second can't occur because if two finite sets are equal they have the same number of elements.
Thus {x}={u} ie x=u. Now {x,y}={u,v} so either x=u, and y=v and we are done, or x=v and y=u, but we know that x=u so y=u=x=v and again x=u and y=v.
The whole point if {x,{x,y}} is to be able to distinguish "x" from "y" and so have the "order" (that is, (x,y) is different from (y,x)).
There are two main features of this definition of (x,y).
One is that it is based on sets. Thus you can do a lot of math with sets without having to invent all sorts of new objects that aren't sets. (Not all of math reduces to set theory.)
Two is that although one can define an ordered pair any way one wishes, the spirit of an ordered pair, something that any "reasonable" definition of an ordered pair should satisfy is that
(x,y)=(a,b) if, and only if, x=a and y=b.
You can check right off the bat that this is not true if you define (x,y) to be {x,y}. But it is true for {{x},{x,y}}. You could define ordered pairs differently, so long as the above iff holds, but this seems to be the simplest definition in which the above iff is maintained.
First Post .
Also note the following:
AxB={(x,y): x€A and y€B} .
Thus the elements of AxB are of form {x,{x,y}} .
By you can derive , if my memory is still good ,
AxB is a subset of P(P(A union B)) where P denotes the powerset map .
Thanks to each of for the great info. I think I understand now.
BTW - when I need to prove something that takes the logical form p iff q, do I have to go about it by showing that p implies q (assume p to derive q) and then show that q also implies p (assume q to determine p)? I guess what I'm asking is if there is any preferred (or even required) logical structuring that need to be adhered to in presenting the proof? I see some proofs that seem to follow formal logic and others that are kinda loose. Do you know what I mean?
Thanks,
Perion
Thanks,
Perion
When proving iff, you can
1. do what you said exactly
2. instead of using if at each step, use iff. For example, often when you prove that x is in Z iff x is in W, you can go
x is in Z iff x is in Z' iff x is in Z'' iff x is in Z''' iff x is in W. That suffices.
When proving three or more 'sentences' are equivalent, it's kind of cool. If there are three, for example, you prove if A then B, then if B then C, and finally if C then A. That proves A iff B iff C.
matt, in the following argument you seems to assume that x and y are different.
"If {{x},{x,y}} {{u},{u,v}} them by the definition of equality of sets either
obviously the second can't occur because if two finite sets are equal they have the same number of elements."
i.e. the second case can occur, if x=y=u=v. but then you are done. i.e. you are trying to prove that the first case does occur, rather than proving the second case does not. it is not true that the second case cannot occur, but if it holds, then so does the first.
Notation?
slayerchange said:
First Post .
Hi, I've studied a little set theory and have seen the definition of the cartesian product of two sets to be:
Can you explain how an element of AXB can be an element of {x, {x,y}}?
Thanks in advance - JFo
For the answer to your question, it would behoove you to read the whole thread...
The definition of (x,y) is {x,{x,y}}; so (x,y) is not an element of {x,{x,y}} but is {x,{x,y}}.
I see now... the problem I was having was that I didn't truly know the def. of an ordered pair. Thx
  • · Replies 17 ·
  • · Replies 20 ·
