Looking for some sort of 'cable quick release'
  • Thread starter Thread starter ehilge
    Release Sort
The discussion revolves around finding a suitable 'cable quick release' mechanism capable of handling approximately 3500 pounds of tension. Participants explore various design considerations, potential applications, and existing products that could meet the requirements for a project involving a catapult designed to launch a projectile.
  • Experimental/applied
  • One participant suggests that a pin mechanism may be difficult to implement under high tension and recommends consulting a crane or rigging company for potential solutions.
  • Another participant emphasizes the need for clarification on whether the connection must be reusable or if cutting the cable is an option, as well as whether full disconnection or partial load support is acceptable.
  • A participant mentions the need for a quick release that can handle the load instantaneously, indicating a preference for a mechanism that could be destroyed and easily replaced, similar to an explosive bolt but not actually explosive.
  • Links to commercially available products, such as a quick release snap shackle and a trebuchet trigger, are shared, with questions raised about their suitability for the specified load conditions.
  • Concerns are expressed about the safety and feasibility of quickly dropping loads that are under tension, with a suggestion to over-engineer the solution if necessary.
Participants do not reach a consensus on a specific solution or product. Multiple competing views and suggestions remain, reflecting uncertainty about the best approach to achieve the desired quick release mechanism.
Participants highlight the need for a thorough stress analysis if designing a custom solution, indicating potential limitations in using commercially available items without further investigation into their load capacities.
ehilge
I'm working on a design project and I need to find what I would call a 'cable quick release'. Basically, I need to be able to quickly release a cable that has ~3500 pounds of tension in it. Ideally, one would just use a pin you could pull out, but I'm fairly certain that would be difficult if not impossible. I've searched around google for such a device but have come up empty handed. Any ideas where I could find one or even what to call it?
Hello,
I am sorry to say I cannot direct you exactly to what you are looking for. However, I would suggest you locate your nearest Crane or Rigging company and inquire about this.
Or, I recall seeing such a device used on the show "MythBusters" when they want to drop a heavy suspended object (such as a vehicle, or weights). I would try researching this route.
Sorry I cannot be of more help. Good luck in your search.
You could help to narrow the search if you would specify whether the connection needs to be reusable or not (can we simply cut the cable?), does it have to fully disconnect or does it simply need to release the load support while maintaining partial engagement (full separation is perhaps more difficult than simply dropping support for the load).
In short, spell out more fully what you want to accomplish with this disconnect and it may become more evident how to accomplish it.
VictoryMike: Thanks for the suggestion. Funny you bring up mythbusters since I was just thinking about that, what they have is exactly what I need.
OldEngr: Ideally it would need to be reusable, we definitely wouldn't be able to just cut the cable. I would be ok if part of the release was destroyed and then that part was easily replaced i.e. something similar to an explosive bolt, but not explosive. If I understand the second part of your question right, it would need to fully disconnect. I want all of the load off the cable instantaneously.
The application for this is for a catapult that's designed to launch a 3 kg projectile 50 meters. The energy must be stored in a spring. Turns out you need quite a bit of energy and some rather large springs, roughly 3,500 pounds worth. Anyway, we need to be able to compress the springs and then release them quickly. We plan on using a winch/ratchet with a cable/strap to compress the springs, but we haven't found a way to separate the springs from the tether yet. Thus why I'm posting this now. If you desire any more details, let me know.
Also, I found this: http://www.wichard.com/rubrique-Quick_release_snap_shackles-0202040300000000-ME.html
Its made for some sailing application, and it looks like you just pull the string and the shackle releases. But can you tell if it would release under load?
I am not confident that this will trigger a 3500 lb load, but here are plans I found for a trebuchet trigger, it could serve as a nice starting point.
here
I actually found that trebuchet trigger before. That is along the line of what I need, but I would prefer to be able to use a commercially available item. If I design something myself, I would need to do a complete stress analysis on every component of it which is more work than I need right now.
You might have to, it's not generally advisable to drop loads (suspended or with otherwise stored energy) quickly and uncontrolled. For times when it is, the parts are usually application specific. I'm not saying you will not find something that works, but I can't imagine it will be easy.
If it comes down to it, over-engineer it.
If you're still looking for ideas, I know load wise you are still on your own but these exist.
http://www.perfski.com/Waterskis/Trick-Skis/Masterline-Robbins-Trick-Release.html
  • · Replies 20 ·
