Mass of fuel burned in car over distance with changing mass
  • Thread starter Thread starter Belginator
    Car Fuel Mass
The discussion revolves around calculating the mass of fuel burned by a car over a distance while considering changing mass due to fuel consumption. The problem involves concepts from mechanics, specifically forces acting on a vehicle, energy content of fuel, and the relationship between power, mass, and distance traveled.
  • The original poster attempts to relate the power required to maintain constant velocity with the energy content of the fuel, raising questions about the impact of changing mass on fuel consumption. Some participants question the relevance of vehicle weight in the context of the frictional force, while others clarify that the frictional force is dependent on the instantaneous weight, suggesting that the power required decreases as the vehicle becomes lighter.
Participants are exploring various interpretations of the problem, with some suggesting the formulation of equations that relate power input to power expended. There is an acknowledgment of the complexity introduced by changing mass and its effect on fuel consumption, but no consensus has been reached on the correct approach or solution.
The discussion includes assumptions about the vehicle's shape, the nature of forces acting on it, and the relationship between power and fuel consumption. There is an emphasis on the need to express variables in terms of distance rather than time, which adds complexity to the problem.
Belginator
Hi! I seem to be having some difficulty with this one, any help would be appreciated. There is a car, assume it for simplicity to be a rectangular prism of dimensions l,w and h. The car is moving at a constant velocity [itex]v[/itex], and assume there is a drag force [itex]D = 0.5 \rho v^2 C_D h w[/itex] and a frictional force μ. We know that the fuel has an effective energy content of [itex]E_f = 15kWh/kg[/itex]. The total mass of the car is defined as M + m, where m is the fuel mass and M everything else. R is the distance the car travels. Essentially how much fuel is needed to go a certain distance R, knowing that over the distance the car gets lighter as fuel is burned, which means the force required to keep the constant velocity decreases.
2. The attempt at a solution
My thought process is that the Power required to keep the car moving at the constant velocity is the amount of power needed from the fuel. The power required: [itex]P_{req} = (μ(m+M)g + D)v[/itex]. I think the average power of the fuel can be defined as: [itex]P_{fuel} = \frac{E_f m v}{R}[/itex] I want everything in terms of distance rather than time that's why I have v and R in that equation rather than time.
I believe fuel power is average since it's over a distance, R, so to make it instantaneous power I say: [itex]P_{fuel} = \frac{E_f dm v}{dR}[/itex]. The power required by the car is already instantaneous since m is instantaneous and changes over R (or time, same thing, as fuel is burned).
I set the power required and the fuel power equal to each other as follows:
[itex]\frac{E_f dm v}{dR} = (\mu (m+M)g + D) v[/itex], the v's cancel. separation of variables:
[itex]\frac{E_f}{\mu g (m+M)+D} dm = dR[/itex]
After integrating and solving for fuel mass, m:
[itex]m = \frac{e^{\frac{\mu g R}{E_f}} - D}{\mu g} - M + C_0[/itex]
It seems to make sense that the mass of fuel m needed to drive a distance, R of 0 is 0. Using that as the initial condition to solve for [itex]C_0[/itex] I get:
[itex]m = \frac{e^{\frac{\mu g R}{E_f}} - 1}{\mu g}[/itex]
That doesn't make logical sense however, it should be a function of drag and velocity as well, I would think, because if you have two cars, one with a higher velocity than the other, but constant, the higher velocity car should burn more fuel since it has more drag. Perhaps my setup is completely wrong, I don't know. Again, any help is appreciated, thanks.
If the frictional force is mu as stated in your problem statement, why are you concerned with the weight of the vehicle?
μ is actually stated as a percent of the instantaneous weight. So the frictional force: [itex]F_f = \mu mg[/itex] changes as mass changes which changes the power required to keep the velocity constant. The power required to keep the constant velocity, I believe, would be exponentially decreasing, as less and less fuel is required to maintain the velocity due to a lighter and lighter vehicle.
Can you write an equation that relates the power input to the power expended? You basically have it with your first equation:
P = (mu(m+M)g+D)v
The power input can be written in terms of fuel consumption
P = (dm/dt)E
If you solve the differential equation with time as the independent variable, you get an expression for m in terms of t. The t variable can always be related to R, the range, by dividing R by v.
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 42 ·
