Register to reply
Rate of Field Change for Induced Current of Loop
by tevatron1
Tags: emf, induced current, loop, magnetic flux
Share this thread:
tevatron1
#1
Feb21-12, 11:14 AM
P: 11
A single conducting loop of wire has an area of 8.010−2 m^2 and a resistance of 110 Ω. Perpendicular to the plane of the loop is a magnetic field of strength 0.37 T.
At what rate (in T/s) must this field change if the induced current in the loop is to be 0.33 A?
2. Relevant equations
Trying to solve for ΔB/Δt
3. The attempt at a solution
We have a change in magnetic flux, but it seems to be due to ΔB rather than ΔA, so Δflux = ΔB*Acosθ (However since cos(90) = 0, I'm not sure if this will be correct).
Using Faraday's Law |ε| = N|(Δflux/Δt)|
Substituted Δflux = ΔB*A into Faraday's Law --> ε = N(ΔB*A/Δt)
Substituted the equation for the induced EMF into I = |ε|/R and solved for ΔB/Δt
ΔB/Δt = I*R/A (N=1 because the loop has 1 turn)
453.75 T/s = (.33A)*(110Ω)/(8.0*10^-2 m^2)
asks for 2 significant digits -> 450 T/s = Final Answer
I'm not sure where I'm going wrong...
Phys.Org News Partner Science news on Phys.org
Apple to unveil 'iWatch' on September 9
NASA deep-space rocket, SLS, to launch in 2018
Study examines 13,000-year-old nanodiamonds from multiple locations across three continents
kushan
#2
Feb21-12, 11:21 AM
P: 259
Quote Quote by tevatron1 View Post
[/b]
θ would not be 90 as Area vector and B make 0 angle
tevatron1
#3
Feb21-12, 11:26 AM
P: 11
Quote Quote by kushan View Post
Okay, then cos(0) = 1, which would prove that my assumption Δflux = ΔB*A*cos(0) = Δflux = ΔB*A
How does the rest of my thought process look?
kushan
#4
Feb21-12, 11:31 AM
P: 259
as as i know you are doing correctly ,
where are you stuck ?
tevatron1
#5
Feb21-12, 11:32 AM
P: 11
Mastering Physics tells me this is the wrong answer, though it does not give any explanation as to why.
kushan
#6
Feb21-12, 11:33 AM
P: 259
what is " mastering physics "
tevatron1
#7
Feb21-12, 11:35 AM
P: 11
It's the online website for our physics homework. When you enter your answer, you are told whether or not your answer is correct. You are given 5 attempts, during which the points you earn diminish.
kushan
#8
Feb21-12, 11:37 AM
P: 259
Even I am in confusion as they have given magnitude of magnetic field
(which means a constant field ) but asking find at what rate it would vary
tevatron1
#9
Feb21-12, 11:39 AM
P: 11
Yes, I noticed this as well. I purposely left that out of my equation as we are attempting to solve for ΔB/Δt. I assume it's the authors of the homework trying to trick us into thinking the value is necessary. Though I cannot see how it could be.
kushan
#10
Feb21-12, 11:44 AM
P: 259
I am sorry as I fail to help you further with this problem
technician
#11
Feb21-12, 12:04 PM
P: 1,506
You know the resistance of the loop and you know the current so you should be able to find the induced emf
tevatron1
#12
Feb21-12, 12:12 PM
P: 11
"I am sorry as I fail to help you further with this problem "
Thanks, Kushan. I appreciate your help. I think there might be an issue with the website. It wouldn't be the first time.
Technician: You might notice that is exactly what I attempted to do... No worries though.
tevatron1
#13
Feb21-12, 12:26 PM
P: 11
As it turns out, the website wanted a different number of significant figures. Albeit, an incorrect number with the given information...
kushan
#14
Feb22-12, 12:26 AM
P: 259
Thank god
Register to reply
Related Discussions
Current induced in a loop inside a fluctuating field General Physics 0
Induced current in a loop circuit magnetic field Introductory Physics Homework 1
Induced Current in a Loop - Changing B Field General Physics 2
Current in Induced Loop Advanced Physics Homework 1
Induced emf in a current loop Introductory Physics Homework 4
