Matlab input string as variable name (or other ways)
This discussion addresses the challenge of using input strings as variable names in MATLAB. Users attempted to directly assign user input to a variable for computations like sum and mean, which resulted in errors. The recommended solution involves using the eval() function to convert the input string into a variable, ensuring to check if the variable exists in the workspace with exist(). Additionally, a switch-case structure is suggested for selecting datasets based on user input.
  • Familiarity with MATLAB scripting and functions
  • Understanding of variable scope in MATLAB
  • Knowledge of the eval() and exist() functions
  • Basic understanding of control flow structures like switch-case
  • Explore the use of eval() in MATLAB for dynamic variable assignment
  • Learn about variable existence checks using exist() in MATLAB
  • Investigate control flow structures in MATLAB, particularly switch-case statements
  • Research best practices for user input validation in MATLAB scripts
MATLAB developers, data analysts, and anyone looking to enhance their scripting skills by effectively managing user input and variable assignments.
ghostyc
Hi,
I am writing a Matlab function(script), which take some input.
I have several datasets in the workspace, say dataset1,dataset2,dataset3, ect
In my function, I have tried to use
data = input('Please input your dataset', 's')
and then use 'data' as a variable for some computation, say
sum(data);
mean(data);
It does not work. I wonder what's the 'correct' way to do it?
OR, I can add an argument in myfunction, say
function y = myf(ds,para)
use 'ds' to indicate the dataset that i want to use.
However, in this case, how should i use 'fminsearch' for optimization?
'fminsearch' will then treat this 'ds' input as a parameter.
Thanks!
No, that is not possible. You cannot take the variable name as input. Use either switch-case or if-else:
Code:
choice = input('Enter dataset number: ');
syms data;
switch choice
    case 1
        data = dataset1;
    case 2
        data = dataset2;
    %so on...
end
Then use "data" as your variable.
ghostyc said:
Hi,
sum(data);
mean(data);
The original post was from 7 years ago, but for the benefit of anyone else:
eval() takes a string argument and executes it as code.
It is of course necessary to check that the input string is the name of a variable before executing it, as the example on that page shows (but without telling the user that they've done something wrong).
Code:
datasetName = input('Please input your dataset', 's')
if(exist(datasetName, "var"))
   data = eval(datasetName)
else
   error("There is no variable called %s", datasetName)
end
10K
