Does this involve calculus? im confused help please
  • Thread starter Thread starter pringless
    Calculus Confused
The problem involves two objects moving along the x-axis, with their positions given as functions of time. The objective is to calculate the magnitude of the distance of closest approach between the two objects.
  • Participants discuss the need for calculus in solving the problem, with one suggesting that the problem can be approached by treating the position functions as a quadratic equation. Others express confusion about the suggested methods and seek clarification.
The discussion is ongoing, with some participants providing guidance on graphing the equations and analyzing the difference between the two positions. There is a lack of consensus on the necessity of calculus, and multiple interpretations of the problem are being explored.
Participants are navigating through different methods of analysis, including graphical representation and algebraic manipulation. There is uncertainty regarding the interpretation of the problem and the role of calculus in finding the solution.
pringless
Hint: x_1 and x_2 never have the same value. The x-coordinates of two objects moving along the x-axis are given below as a function of time t. x_1 = (4m/s)t x_2 = -(25m) + (8m/s)t - (2m/s^2)t^2 Calculate the magnitude of the distance of closest approach of the two objects.
Hi pringless,
no, you do not need calculus to solve this.
Let's call x(t) = x1(t) - x2(t).
This is just quadratic in t (the graph is a parabola).
All you got to do is find the lowest (or highest) point of the parabola.
Let's call that point (t0, x0), then we can write
x(t) = a(t - t0)2 + x0.
You can find a, t0, x0 by matching the coefficients on both sides. OK?
im sorry...i don't really understand what u mean
Pringless,
Graph the two equations. That will show you position of each particle as a function of time.
If you then subtract one from the other, you'll have the difference between the two. If you graph that, you'll see the difference as a function of time. You'll see that it will go down and then go back up. The closest approach is where the difference is the smallest.
  • · Replies 45 ·
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 22 ·
