Cyclic Permutation in C: Create Alphabet Pattern with Nested For Loops
  • Thread starter Thread starter TheSourceCode
    Cyclic Permutation
The discussion focuses on generating cyclic permutations of the English alphabet using nested for loops in C programming. Participants emphasize the importance of the modulo operator (%) for wrapping characters from 'z' back to 'a'. One user suggests an alternative approach involving a single loop and array manipulation but ultimately acknowledges the effectiveness of using two loops with modulo for clarity and correctness. The consensus highlights that understanding the modulo operator is crucial for implementing this pattern efficiently.
  • Understanding of C programming syntax and structure
  • Familiarity with nested loops in programming
  • Knowledge of character encoding in C (ASCII values)
  • Comprehension of the modulo operator (%) and its applications
  • Implement cyclic permutations using nested for loops in C
  • Explore character manipulation techniques in C programming
  • Study the use of the modulo operator in various programming scenarios
  • Learn about alternative methods for generating patterns without nested loops
C programmers, computer science students, and anyone interested in algorithm design and character manipulation techniques.
TheSourceCode
Use nested for loops to produce the following pattern of cyclic permutations of the English
alphabet:
abcde...yz
bcdef...za
cdef...zab
zabcde...xy
HINT: you may find the modulo (remainder) operator % useful.
I have an idea of how to do this but it would not use the modulo operator. I thought of saving the first letter of an array into a variable, shifting everything else down one and putting it at the end. This also would only implement a single for loop. Any clues would be greatly appreciated.
Yes, there are probably a million ways to do this, but I suggest that you have one loop generating the first character of each string and an inner loop (since that what was asked for) generating the successive letters of each string - using modulo operator to make the wrap from z to a.
Thanks a lot. Took me a bit to get the wrap around to work properly but I got it. I don't think modulo was very intuitive to me before but now I get it.
11K
