Central force - circular motion
The discussion revolves around the conditions under which a body can maintain exact circular motion under a central force. Participants explore various forms of central forces, their implications for circular orbits, and the stability of such orbits in different scenarios.
  • One participant suggests that the form of the central force can be expressed as F = -M · w² · r, implying a specific mathematical relationship for circular motion.
  • Another participant argues that while gravity can lead to circular orbits, it is the initial velocity that is crucial, and true circular orbits may not exist for planets due to various forces acting on them.
  • A different viewpoint states that any central force where the potential is solely a function of radius (r) can yield circular orbits, with gravity being a specific example where circles are particular cases of elliptical orbits.
  • One participant mentions that a central force that is uniform with respect to angle can allow for circular motion, but the stability of such orbits depends on the effective potential, which can be analyzed through the conservation of angular momentum.
  • It is noted that an inverse cube law force is an example of a marginally stable case for circular orbits, while higher power laws lead to instability.
Participants express differing views on the nature of central forces and their ability to produce stable circular motion. There is no consensus on a single form of central force that guarantees exact circular motion, and the discussion remains unresolved regarding the implications of different forces on orbit stability.
Participants highlight the importance of initial conditions, the nature of the force, and the mathematical relationships governing motion, indicating that assumptions about uniformity and stability are critical to the discussion.
spacetime
For what form of a central force is the motion of a body exactly circular?
Just keep
[tex]F = - M \cdot w^{2} \cdot r[/tex]
Good question. Spacetime -- I cannot speak for every form of force , but if you take gravity as an example it is not the force per se which gives you a circular orbit -- it is the initial velocity ( meaning speed and direction ) I do not think that there is a single planet in truly circular orbit.
If you write the equations balancing the force of gravity with the so called centrifugal force they can only balance exactly ( and hence cancel ) if the motion is tangential to gravity other wise you will be left with a component pointing somewhere else an an ellipse or some sort will occur.
I do not think the equation of gravity matters so long as it points outward from a point ( assuming you are outside the defind body ) ( i.e. for a gas you may not quite be totally inside ).
The previous answer is good but does not relate to type of force , in a more general sense if you had more than one source of gavity ( as an example two suns )
two protons etc etc . there maybe no solution at all -- even if they are close .
Example even if you can consider the Earth as a point source of force from a fair distance you could not ignore a mountain if you were in close Earth orbit , and probably there would be NO circular solution.
So circular implies highly regular force in the space , and a specific orientation to the start of motion.
Ray
Any form where the potential is a function only of r has a particular solution that is a circle.
So for example gravity has circular orbits: the general orbit is elliptical and circles are particular instances of ellipses. You get circles if the system is set up exactly right for it.
You can put a mass on a spring and swing it round in a plane (F is proportional to r-r_0). For every r, you can find a velocity where the centrifugal force is equal to F at some r. But deviate away from this r for the same v and you get a sine wave wrapped in a circle.
Kittel gave the correct answer since a central force was specified by Spacetime meaning that the force depends only on the separation and is directed from one object to the other.
Any central force that's uniform with the angle (i.e. where the force is not a function of angle) that is attractive will allow a circular motion, but such an orbit may or may not be stable.
The stability of the force can be investiaged by looking at the plot of the "effective potential". It turns out you can reduce the two dimensional problem to a one dimensional problem for a uniform central force (by making use of the conservation of angular momentum). It turns out that the equations that govern the radial motion of a particle are exactly the same as a classical particle in a potential well. The stability analyis is then very simple - if the particle is "on a hill", it will slide off, and the circular orbit won't be stable. If the particle is "in a valley", the orbits will be stable. The marginal case is where the effective potential is flat - in this case, any small error will cause a circular orbit to drift away, but it won't be actively unstable as it would if the particle were on a hill.
An inverse cube law (f=-k/r^3) is an example of the marginally stable case where the "effective potential" is flat. Any power law higher than inverse cubic is actively unstable (i.e f = -k/r^4 , -k/r^5, etc are unstable).
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 37 ·
  • · Replies 18 ·
  • · Replies 67 ·
