Magnetic field inside a material
The discussion revolves around the behavior of magnetic fields inside ferromagnetic materials, specifically focusing on the relationship between magnetization (M) and the additional magnetic field produced (uoM). Participants explore theoretical underpinnings, seek intuitive proofs, and clarify concepts related to magnetic fields and magnetization.
  • One participant questions how the additional field is equal to uoM, expressing a need for intuitive proof or clarification.
  • Another participant explains that in a ferromagnetic material, the magnetic field B is given by B=uo(H+M), where H includes contributions from the applied field and the demagnetizing field (Hd).
  • It is noted that Hd has a negative effect on B and depends on the geometry of the material and M.
  • A participant references a visual demonstration linking magnetic fields and magnetic moments, suggesting that the relationship B=uoM is derived from experimental observations in solenoids.
  • Concerns are raised about the accuracy of the formula B=uo(Mo + M) when applied to finite-length cores, with a participant arguing it only holds for infinitely long cores.
  • Further elaboration on the nature of magnetic fields and their measurement is provided, discussing the concept of solenoidal fields and the relationship between cause (magnetization) and effect (magnetic field).
  • Discussion includes the historical context of the constant uo and its implications in practical measurements.
Participants express differing views on the validity of certain formulas and the interpretation of magnetic fields in relation to geometry and core length. There is no consensus reached on the correctness of the equations presented, and the discussion remains unresolved regarding the intuitive understanding of the relationship between M and the additional field.
Limitations include unresolved assumptions about the geometry of materials and the applicability of certain equations to finite versus infinite lengths of magnetic cores.
jd12345
IF a material say a ferromagnet is placed in a magnetic field Bo then there will be an additional field due to ferromagnet which is equal to uoM (M is magnetisation)
My doubt is how is the additional field equal to uoM. By considering the units of both this expression is indeed equal to the magnetic field but still I'm not convinced
M is magnetisation which is total dipole moment in the material divided by volume. And if we multiply it by uo we get the magnetic field produced by it?? I'm very unconvinced by this. I just can't believe stuff with no proofs
So please help me - give me an intuitive proof or something so that my mind is convinced
You talk abou the additional field, additional to what?
Well, in a ferro-magnetic material, B=u0(H+M) , where H=Hd+Ha. Hd is called the demagnetizing field and Ha is the applied field. The difference is then u0(Hd+M), which is less than B=u0M because Hd has a negative effect on B. Hd depends on the geometry of the material and on M. For a uniformly magnetized sphere, Hd=-1/3*M
In order to understand Hd, imagine numerous magnet bars ( in fact, the magnetic dipoles) parallel and packed, with the same polarity. The field lines of each bar closes through the fields of other magnets and attenuates them. We can reduce this Hd to zero by making a closed magnetic circuit with no gap.
hi jd12345! :smile:
jd12345 said:
… how is the additional field equal to uoM. By considering the units of both this expression is indeed equal to the magnetic field but still I'm not convinced
see http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/solenoid.html :smile: for a visual demonstration of the connection between magnetic field and magnetic (dipole) moment …
the magnetic field in empty space inside an ordinary electric solenoid (straight and long, or circular) with current I, and n turns per metre, is found experimentally to be B = µonI
but the magnetic moment density is, by definition, Mo = nI
so B = µoMo
(and H = Mo)​
this shows the relation between magnetic fields measured in tesla (T) and measured in ampere-metre (A-m) :wink:
(and if you put a magnetic core inside the solenoid, it will have induced magnetic moment density M, and the field will now be B = µo(Mo + M))
tiny-tim said:
hi jd12345! :smile:(and if you put a magnetic core inside the solenoid, it will have induced magnetic moment density M, and the field will now be B = µo(Mo + M))
Sorry , I believe your last formula is incorrect except for an infinitely long core.
If you puts a cylinder core with length L inside an infinitely long solenoid, the B-field in the core is less than if you put a a cylinder with with length 2L. Your equation is not compatible with this fact.
yes, i said straight and long :smile:
further thoughts :rolleyes:
µo is a constant which should be "1" (see bottom)
the magnetic field is measured by its effect (via the Lorentz force), the magnetisation field is measured by its cause (induction by an actual or a theoretical system of currents in loops) …
if µo was "1", that link between cause and effect wouldn't be surprising
let's see a "visual" proof of that link:
any magnetic field can be replaced by an identical solenoidal field, as follows:
a solenoidal field is a region R of space with a "honeycomb" of thin hexagonal solenoids (they needn't be hexagonal: but that makes them fit nicely :wink:), each with a (different) current Ii, and a (different) pitch, ni (pitch is turns per length)
the solenoids aren't straight, they can be curved into any shape
that causes ("induces") the whole region R to be filled with a magnetic field, of "Lorentzian" strength µoniIi inside each solenoid
this is of course the same as µoMi, where Mi is the magnetic moment density of each solenoid, measured in amp-turns per metre
(magnetic moment per turn = IiA, where A is the cross-section area of that turn; so magnetic moment per volume = IiA times turns per volume = Ii times turns per length = Iini = Mi)​
now consider any B field in any region R
we can fill R with an imaginary honeycomb of solenoids whose sides follow the B field lines (ie lines of constant |B|, and whose tangent at each point is parallel to the B field at that point), and whose current or pitch (or both) are adjusted so that the solenoidal field equals the B field along the centre line of each solenoid …
and by making the number of solenoids large enough (ie, the diameters small enough), we can make the solenoidal field match the whole B field to any required degree of accuracy
in other words: in the limit, any actual B field can be replaced by a purely solenoidal field​
B fields are naturally measured by their effect, in units of force per charge per speed (N.s/C.m = N/A.m = tesla)
(we could call these either "Lorentzian units" (named after the Lorentz force q(E + v x B)), or "Laplacian units" (named after the Laplace force qv x B))
solenoidal fields are naturally measured by their cause, in units of magnetic moment density, measured in amp-turns per metre, or A-turn/m (or, in SI units, simply but confusingly :redface: A/m)
the conversion ratio between these cause and effect measurements is a universal constant, µo, which should be "1", in units of N/A2 (Newtons per amp per amp-turn) :smile:
why isn't this unit "1" ? :confused:
well, it would be :smile:, buuuut :rolleyes:
i] in SI units, a factor of 4π keeps cropping up! … so we multiply by 4π :wink:
ii] that would make the amp that current which in a pair of wires a metre apart would produce a force between them of 2 N/m …
which would make most electrical appliances run on micro-amps!
so, for practical convenience only, we make µo 107 smaller, and the amp 107 larger! :biggrin:
(so the amp is that current which in a pair of wires a metre apart would produce a force between them of 2 10-7 N/m, and µo is 4π 10-7 N/A2 (= 4π 10-7 H/m))
(for historical detaills, see http://en.wikipedia.org/wiki/Magnetic_constant)
fair enough - thank you
Thanks tiny-tim. Now I understand why a divergence-free field is called a solenoidal field.
  • · Replies 42 ·
  • · Replies 26 ·
13K
