Convergence of a sequence of integrals
The sequence $$\left( \int_a^b (f(x))^n \, dx \right)^\frac{1}{n}$$ converges to the supremum M of a continuous, non-negative function f defined on the interval I=[a,b]. The approach involves defining g_n(x) and demonstrating its convergence to a function g(x) uniformly. By establishing a point x_o where |f(x_o)-M| < ε/2 and applying continuity, one can derive bounds that lead to the conclusion that the sequence converges to M as n approaches infinity.
  • Understanding of sequences and limits in real analysis
  • Familiarity with the properties of continuous functions
  • Knowledge of the supremum and its implications in integration
  • Basic proficiency in applying the triangle inequality in proofs
  • Study the concept of uniform convergence in real analysis
  • Learn about the properties of integrals and their behavior under limits
  • Explore the implications of the triangle inequality in mathematical proofs
  • Investigate the relationship between continuity and supremum in function analysis
Students and educators in mathematics, particularly those focusing on real analysis, integration, and the convergence of sequences of functions.
Locoism
Let I=[a,b], f : I to R be continuous and suppose that f(x) >= 0 . If M = sup{f(x):x ε I} show that the sequence $$\left( \int_a^b (f(x))^n \, dx \right)^\frac{1}{n}$$
converges to M
Where do I start? I'm thinking of having [tex]g_n(x)= \left( \int_a^b (f(x))^n \, dx \right)^\frac{1}{n}[/tex] and showing that converges to a function g(x) (uniformly?) but that just feels like restating the problem.
If I can show that there exists [itex]x_o[/itex] such that [itex]|f(x_o)-M| < \frac{ε}{2}[/itex] , and by continuity if [itex]|x-x_o| < δ[/itex] then [itex]|f(x)-f(x_o)| < \frac{ε}{2}[/itex] and then triangle inequality it up to show [itex]|f(x)-M| < ε[/itex]
I still feel this gets me nowhere. Any ideas?
Well you can trivially bound it from above, so just work on bounding it from below. Can you find an interval over which f(x)>M(1-ε), if so ∫f(x)ndx>δ Mn(1-ε)n. What happens to this bound when you raise it to 1/n?
  • · Replies 34 ·
