Arithmetic sequence, geometric sequence
The discussion revolves around the conditions for numbers p, q, r to form both an arithmetic sequence and a geometric progression. Participants are exploring the definitions and relationships between these sequences.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to derive the conditions for p, q, r to satisfy the properties of an arithmetic sequence. There are discussions about extending these conditions to more terms and the implications of having an odd or even number of terms.
Some participants have offered equations that relate the terms in the sequences, while others are questioning the validity of these equations in different contexts. There is an ongoing exploration of how these relationships hold as the number of terms increases.
There is mention of previous misunderstandings regarding the problem statement, and participants are navigating the complexities of defining sequences with varying numbers of terms.
sg001
Posted this thread earlier but had mis read the given answer. please disregard older thread as I don't know how to delete it!
Write down the condition for the numbers p, q, r to form an arithmetic sequence & geometric progression.
\ a_n = a_1 + (n - 1)d, ?
Have no idea, tried looking for similar examples on the net but they all seem to include numbers that are euidistant ie 5, 7, 9, 11...
All help is appreciated if someone could point me in the right direction about how to go about this!
hi sg001! :wink:
sg001 said:
Write down the condition for the numbers p, q, r to form an arithmetic sequence …
well, isn't that the answer, then? :smile:
so just to make sure i understand what's goin on here.../
If i had the same question but now with a,b,c,d,e,f.
The conditions for arithmetic sequence containing these numbers would be...
a = 1/5(b+c+d+e+f)
i] nooo
ii] just do it for p q and r …
what is the equation that p q and r (only) have to satisfy?
(in other words: translate what you've already said into an equation :wink:)
ok so it is
p= 1/2 (q +r)
but is this the case for questions with a larger amount of terms
ie p,q,r,s,t,u
where i can say to satisfy an arithmetic sequence
p= 1/5 (q +r+ s+t+u)
because this is how I am understanding what's goin on
ie 2p = q +r
& 5p = q + r +s +t +u
Or does it only work because q is the middle term
Therefore p & r are equidistant from q .
Hence, q = 1/2 (p + r)
So it will only work with an odd amount of numbers ie a,b,c or a,b,c,d,e
By working it out simply that is??
hi sg001! :smile:
sg001 said:
ok so it is
p= 1/2 (q +r)
you mean q = 1/2 (p +r) :wink:
no, you need an extra equation for each extra term
(eg 5 terms, 3 equations)
Okie I understand now.
Thankyou
  • · Replies 51 ·
  • · Replies 24 ·
