| New Reply |
Designing Titanium Carbon Uprights for racecar |
Share Thread | Thread Tools |
| Feb25-12, 08:45 AM | #1 |
Hello,
For my University project I am trying to design uprights for a race car. Currently we are using TIG welded 4130, I am trying to push the Titanium carbon direction. I have many questions! The idea of the upright is to use a titanium core (manufacture from laser sintering) then skin it with carbon fiber. This should mean the core will have good compressive strenght and the skin will have a high tensile strenght. One of the quierys I have is what the structure of the core should look like. The sintering machine can do a repeated pattern to build up a 3d object, What is the best pattern for the core? I was thinking a honey comb structure. Please help, Thank you. |
| Feb27-12, 12:48 PM | #2 |
What makes you think titanium and carbon are a good match mechanically? High-strength Titanium alloys have high yield strengths, and relatively low density and elastic modulus. This means they tend to bend farther than steel for a given force but have a high strength to weight ratio compared to steel. carbon fiber composites on the other hand have very high modulus or elasticity and high ultimate strength; they bend very little under force but tend to fail catastrophically when pushed to the limit.
My thinking is if you want a very light and strong structure, just go with straight carbon fiber or maybe a carbon-fiber composite paired with some other high strength fiber like kevlar. Adding the titanium core in the middle isn't gaining you anything a novel geometry can't (or even just alunimum or magnesium which are lighter), and the dissimilarities between the materials will play havoc with bonding and thermal expansion. |
| Feb27-12, 02:03 PM | #3 |
I agree with Mech_Engineer on using straight carbon fiber instead.
carbo-titanium alloys have been around for a while, but are scarcely used because of their high cost and bonding problems. NASA did a study on this back in the 70's, but I am unsure what the results were. If you do decide to do it, then yes the honeycomb pattern will do just fine. |
| Feb27-12, 02:47 PM | #4 |
| Feb27-12, 02:58 PM | #5 |
Nonetheless, I still would be a strong advocate of straight CF as you suggested, especially considering the application. |
| Feb27-12, 03:01 PM | #6 |
When it comes down to it, the large mismatch in modulus of elasticity between CF and Ti make what the OP is proposing a bad idea; the portion that deflects the least will take the majority of the force in tension or compression. In the end, the design would end up something like a bad combination of a bimetallic strip and statically indeterminate structure. |
| Feb27-12, 03:21 PM | #7 |
I wonder, would the opposite gain you anything (CF w/ Ti coating)? The titanium could offer flexibility, and a greater resistance to impact forces (may be applicable in a racing situation), while allowing the overall structure to be lighter weight than straight Ti. |
| Feb27-12, 03:25 PM | #8 |
In my estimation the only thing a coating on a CF component gets you is more abrasion resistance; no need for that to be titanium though it could be any number of abrasion-resistant materials (aluminum or HDPE for example).
LOTS of race vehicles utilize all sorts of carbon-fiber components. Usually the only thing in a race car's chassis that can't be made out of CF is the roll cage for toughness and energy absorption concerns. |
| Feb27-12, 03:31 PM | #9 |
| New Reply |
| Thread Tools | |
Similar Threads for: Designing Titanium Carbon Uprights for racecar
| Racecar on a circular track | Introductory Physics Homework | 5 | ||
| Carbon-Carbon Bond Energies: Primary vs. Tertiary Carbon | Atomic, Solid State, Comp. Physics | 0 | ||
| Racecar and Centripetal Force | Introductory Physics Homework | 3 | ||
| Sound from a racecar | Introductory Physics Homework | 2 | ||
| Aerodynamics of a racecar undertray | Mechanical Engineering | 1 | ||
