Parameter Regression: Modeling Explained
  • Context: Undergrad
  • Thread starter Thread starter absurdist
The discussion revolves around the concept of parameter regression in modeling, particularly in the context of engineering models and correlations derived from experimental data. Participants explore its application for making predictions in more complex systems based on simpler analytical models.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant inquires about the definition of parameter regression in modeling.
  • Another participant suggests that the term is too vague to refer to a specific mathematical technique and requests more context.
  • A participant explains that parameter regression is used to refine predictions for complex systems by utilizing regressed parameters from simpler, analytically derived models.
  • A later reply reiterates the explanation of using regression to enhance predictive accuracy for complex systems and references Wikipedia as a resource for further information on regression.
Participants do not reach a consensus on the definition of parameter regression, with some expressing uncertainty about its specific meaning and others providing contextual applications.
The discussion highlights a lack of clarity regarding the terminology and its specific mathematical implications, as well as the dependence on context for understanding the application of parameter regression.
absurdist
What is a parameter regression in modeling?
Mathematics news on Phys.org
That terminology is not specific enough to identify a particular technique in mathematics. If you saw it mentioned in some context, you should explain the situation.
It was used in the context of using engineering models/correlations based on experimental data: After obtaining an analytically derived mathematical model for a simpler system to use the regressed parameters to make more accurate predictions for more complex systems.
I tried googling it but in vain:(
They mean exactly what they said: do regression and then use the model to make predictions for a more complex system. Wikipedia has a good article on regression.
  • · Replies 23 ·
