Countably infinite set: odd integers
The discussion revolves around proving that the set of odd integers is countably infinite, utilizing the definition that a set is countably infinite if its elements can be put in a one-to-one correspondence with the set of positive integers.
  • Participants discuss various piecewise functions intended to map positive integers to odd integers, with attempts to demonstrate that these functions are one-to-one and onto.
Some participants have provided guidance on how to show that the proposed functions are onto and one-to-one, while others are exploring different definitions and approaches to clarify the mappings. There is an ongoing examination of the assumptions regarding the parity of integers involved in the mappings.
Participants are working within the constraints of homework rules, focusing on definitions and proofs without providing complete solutions. There is an emphasis on ensuring clarity in the definitions and the implications of the mappings being discussed.
k3k3
Using the definitions, prove that the set of odd integers is countably infinite.
Definition: The set A is countably infinite if its elements can be put in a 1-1 correspondence with the set of positive integers.
I am trying to think of a function that maps the positive integers into the odd integers.
The function I am coming up with is piecewise defined.
I am unsure how to type it, but...
f(n) =
n-2 when n is odd and n>2
-n-1 when n is even
-n when n=1
Testing some values, I got this
f(1)=-1
f(2)=-3
f(3)=1
f(4)=-5
f(5)=3
It looks like this works, but I am unsure how to show a piecewise defined function is 1-1 and onto. I think I am missing something.
You're fine. Actually, you can define the same function in two pieces: n - 2 for odd n and -n - 1 for even n. Furthermore, n for odd n and -n + 1 for even n works as well.
Same way you should show 1-1 and onto for any other function. Show f(n) = f(m) implies n = m. Then show for every odd integer i, there is a natural number n such that f(n) = i.
Thank you for the response!
Running with your suggestion, showing onto is simply stating that:
Let m be an element of the odd integers.
If n is odd, since the sum of an odd and even is odd, then n+(-2)=m for all odd n in the positive integers.
If n is even, since an odd number is defined by 2x-1 for all x in Z, where n=2x, then -n-1=m for all even n in the positive integers.
Is this a satisfactory proof of why f(n) is onto?
I'm not convinced. It doesn't say why m must equal f(n) for some n, but just that it could.
Consider using n for odd n and -n + 1 for even n as your f. It will lead to a simpler proof.
A strategy for examining piecewise functions can be to look at the pieces of the domain where the function is defined separately. For odd n, where does f map n? What about for even n? Is m guaranteed to achieve either of these types of values, and if so, why?
How is this:
Let m be an element in the set of odd integers.
If n is even, then there is a m such that f(n)=m.
Since m is an odd integer, then there exists an element -m+1=n.
Then f(-m+1)=-(-m+1)+1=m
If n is odd, then m=n for all odd n in the set of positive integers.
Yep you showed that f is onto correctly.
Can you show that f is 1-1, or that f(m)=f(n) implies m=n?
I think so.
Assume f(m)=f(n)
If n is even, then
-n+1=-m+1
-n=-m
n=m
If n is odd, then
n=m
How do you know that m is even when n is even? Likewise, how do you know m is odd when n is odd?
I am still assuming that f(n) is piecewise defined. When n is even, f(n)=-n+1 and when n is odd, then f(n)=n
Showing that f(n)=f(m) for both functions is not enough?
f(n) =
-n-1 when n is even
-n when n=1
f(1)=-1
f(2)=-3
f(3)=1
f(4)=-5
f(5)=3
Your function will work just fine, but it's a little complicated.
Consider a function, g(k), going from the odd integers to the positive integers.
You already have f(n) = -n, for n=1, i.e. f(1) = -1. So g(-1)=1, i.e. g(k)=-k, when k=-1. Why not define g(k) = -k for all the negative odd integers. Where would you then map the positive odd integers?
