Solving Relay Problem in Thermistor Controlled Comparator Circuit
  • Thread starter Thread starter Ali Inam
    Relay
The discussion centers on a thermistor controlled comparator circuit that operates a relay to manage a fan based on temperature readings. The user experiences rapid switching of the relay in its normal state, causing instability. The solution proposed involves introducing hysteresis by feeding back a small percentage of the output voltage to the non-inverting input of the operational amplifier (op-amp), starting with a feedback of about 1% and adjusting as necessary.
  • Understanding of thermistor behavior and temperature sensing
  • Knowledge of comparator circuits and operational amplifiers (op-amps)
  • Familiarity with relay operation and control
  • Basic circuit design principles, including feedback mechanisms
  • Research hysteresis in comparator circuits to stabilize relay switching
  • Learn about operational amplifier feedback configurations
  • Explore thermistor characteristics and their impact on circuit performance
  • Investigate relay specifications and their response times in control applications
Electronics enthusiasts, circuit designers, and engineers working on temperature control systems or relay-based applications will benefit from this discussion.
Ali Inam
Hello everyone, I've made a thermistor controlled comparator circuit which has got a relay connected to its output, when the temperature of the thermistor rises, the relay switches and the fan on its output is turned on the coll the thermistor down.
Now, my circuit is working perfectly, but I'm getting a problem with my relay, which is that in normal condition when the coil of the relay is not being charged from the thermistor output, my relay is switching extremely fast and again and again, it switches from NC to NO then again from NO to NC at about twice or thrice per second. But when the coil is charged, it then switches permanently to start the fan connected to it.
I don't know what I must do about the problem I'm facing in the normal condition.
Thanks...!
First, unless the current through the thermistor is what is heating the thermistor, a fan will not cool it. In fact due to the power dissipated by the fan, it will heat the air slightly. The reason blowing air over skin feels cool is that it aids evaporation of perspiration which does cool the skin.
To avoid the condition you describe in which the relay is switching rapidly from one state to the other, hysteresis is introduced by feeding back a small amount of the output voltage to the the non-inverting (+) input of the opamp. I would start with about 1% and adjust it up or down from there.
Can you show the circuit here?
  • · Replies 31 ·
  • · Replies 25 ·
