Relations Involving the Directional Cosines
  • Context: Graduate
  • Thread starter Thread starter Septim
    Relations
The discussion revolves around the relationship between the directional cosines of two vectors and the cosine of the angle between those vectors. Participants explore the mathematical foundations of this relationship, including the use of dot products and matrix transformations.
  • One participant inquires about the proof of the relation between directional cosines and the cosine of the angle between two vectors.
  • Another participant suggests verifying the relation in a simplified case where one vector is aligned along the x-axis, arguing that other cases can be derived through rotation.
  • A participant references the dot product of vectors and expresses uncertainty about how to connect cosines with directional cosines.
  • Further clarification is sought regarding an equation from a referenced text that relates the cosine of the angle between vectors to their directional cosines.
  • One participant expresses confusion about the specific equations being discussed and requests clarification on the references made by others.
Participants do not appear to reach a consensus, as there are multiple viewpoints regarding the derivation of the relationship and the specific equations involved. Some participants are exploring different methods and interpretations without resolving the uncertainties.
There are references to specific equations and expressions from a text that are not fully detailed in the discussion, leading to potential gaps in understanding. The discussion also highlights a reliance on matrix transformations and dot products, which may not be universally understood by all participants.
This discussion may be of interest to those studying vector analysis, particularly in the context of directional cosines and their applications in physics and engineering.
Septim
Greetings,
I wonder if a proof of the relation between the directional cosines of two vectors and cosine between two vectors is available? In order to clarify what I meant I put a screen shot from Vector and Tensor Analysis by Hay.
Verify in the easy case where one of your vectors is (a,0,0) for some a>0. Since every other case can be gotten from the easy one by a rotation (which preserves the angle between the vectors), and since orthogonal matrices preserve the expression involving the direction cosines (use the fact that their rows are unit-length vectors), you're done.
Greetings Septim! :smile:
if you've done dot-products, then:
a.b = (a1i + a2j + a3k).(b1i + b2j + b3k) = … ? :wink:
Thanks for the replies. Tinyboss I will try the method you suggested but I am a bit unfamiliar with matrices. Tiny-tim the author derives uses the expression you see on the attachment to convert the abstract form of the dot product into the component form. My question is that how can he relate cosines with directional cosines. I am still open for other suggestions.
Hi Septim! :smile:
(just got up :zzz:)
Septim said:
… the author derives uses the expression you see on the attachment to convert the abstract form of the dot product into the component form. My question is that how can he relate cosines with directional cosines.
I'm not following you. :redface:
Which equations are you referring to? :confused:
After the expression of the dot product in abstract form, that is Eq.(7.1); the author expresses the cosine between the two vectors in terms of the direction cosines of the individual vectors. This equation is indented; however it does not have an equation number. I actually wonder how that equation can be derived. Forgive me for the late reply by the way.
  • · Replies 16 ·
  • · Replies 58 ·
  • · Replies 33 ·
  • · Replies 16 ·
