How do I Solve these two equations?
  • Thread starter Thread starter adam640
The discussion focuses on solving a system of linear equations represented as ax + by = 0 and cx + dy + e = 0. The simplification of forces FBA and FBC to 0.8081P and 0.7143P respectively is achieved by strategically eliminating variables through linear combination. Specifically, adding -a/c times the second equation to the first allows for the isolation of one variable, facilitating the solution process. This method is essential for simplifying complex equations in engineering contexts.
  • Understanding of linear equations and systems of equations
  • Familiarity with algebraic manipulation techniques
  • Knowledge of axial load concepts in engineering
  • Experience with variable elimination methods
  • Study the method of elimination in solving linear equations
  • Explore applications of linear equations in structural engineering
  • Learn about axial load calculations and their significance
  • Investigate software tools for solving systems of equations, such as MATLAB or Python's NumPy
Engineers, students in structural mechanics, and anyone involved in solving linear equations in engineering applications will benefit from this discussion.
adam640
As part of a question on axial load I need to simplify two equations in terms of P ([1] and [2]).
http://img207.imageshack.us/img207/5757/77260215.png
In the above you can see how FBA and FBC were simplified to 0.8081P and 0.7143P respectively.
I understand both the section prior to this and the one after, though I do not understand how this simplification was carried out.
Any help would be greatly appreciated.
Thanks.
You have a system of equations of the form
\begin{align}
ax+by&=0\\
cx+dy+e&=0
\end{align} The trick to find x and y is always to add a multiple of one equation to the other so that either x and y is eliminated. (In this case, you can e.g. add -a/c times the second equation to the first equation). Then you have an equation with only one variable, and you can easily find its value. Repeat the procedure for the other variable.
