New Reply
What kind of op-amp is that?
Share Thread Thread Tools
Feb27-12, 12:53 AM   #1
Recognitions:
Gold Membership Gold Member
At first I thought a comparator, then I noticed a line connecting the Vout and the lines that connect to V- and V+, so it can't be a comparator, can it? I don't see any other option....
As far as the question, I need to find out the unknown resistors, but I'll start working on it once I figure that basic fact.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Feb27-12, 11:31 AM   #2
Recognitions:
As a start, you can either ignore Rx or the circuit is in saturated mode ... this is a consideration since the output current is defined to be 3 mA. The rest is just the usual KVL equations of an active op amp circuit (input voltages equal etc.).
Feb27-12, 11:35 AM   #3
Recognitions:
Homework Helper Homework Help
Quote by Femme_physics View Post
Looks like an amplifier with feedback, although the feedback mechanism is made a bit trickier due to the presence of Rx. What effect do you suppose the zener diode is going to have?
Rb and R1 form a voltage divider. What voltage are they dividing? What's the op-amp going to try to do with that voltage?
Feb27-12, 11:59 AM   #4
Recognitions:
I'd say it looks a bit like an inverting amplifier, but it's not quite it.
KVL and KCL should tell what it does.
Feb27-12, 01:07 PM   #5
Recognitions:
I hadn't noticed the output voltage is given. Since R1 is given, all components are defined implicitly.
You can solve this problem without writing any KVL equations. Hints: what must Ra be to satisfy Iz_min? What must Rb be to give a 12V output? And finally, what must Rx be to give 3 mA of current flowing into the op amp?
Feb27-12, 01:24 PM   #6
There are a few opamps with open collector outputs. This could be one of them.
Feb27-12, 02:25 PM   #7
I would say it is a non-inverting amplifier with voltage of 5V on the + input and voltage gain of R1/(R1+Rb).
Vout =+12V so Rb can be calculated.... and so on
Feb27-12, 03:07 PM   #8
Recognitions:
Quote by technician View Post
Nope on your gain expression ... but you're warm ...
Feb27-12, 04:13 PM   #9
gain of (R1+Rb)/R1 = 12/5 = 2.4
Feb29-12, 03:40 AM   #10
Recognitions:
Well, this is the solution my classmate offered
I agree on Ra. It's just KVL.
But on Rb-- I'm confused as far as how to use a voltage divider.
I CAN indeed apply KVL
Since I know that the 3 mA split at this point marked in red:
I know that there's only 1 mA going through Rb and R1, and I know they have a 12V potential difference to the ground. So,
Sum of all V = 0 ; 12 - 1ma x Rb -1ma x R1 = 0
I get that Rb 2000 ohms. Makes sense?
As far as Rx -- well, I don't really understand something fundemental about the circuit. Is Vs some type of another Vout? Or does it just define the limits of the Op-Amp like we see in those Vcc+ Vcc- sort of thing? I really don't know how to approach Vs. How can 25 Volt comes out of an op-amp who only produces a Vout of 12v?!? And how does any of that helps me with Rx?
Sorry-- A lot of questions, I know. Just a confusing circuit!
Feb29-12, 07:00 AM   #11
Recognitions:
+Vs is the power supply (you've previously seen it as +Vcc) to power the OP-AMP. There is no -Vcc here, the negative power supply here is ground (you've previously seen OP-AMP's negative supply as -Vcc, but not with this arrangement here).
Feb29-12, 07:05 AM   #12
Recognitions:
Proof please!
Feb29-12, 07:13 AM   #13
Recognitions:
Are you referring to the words he's written to the right of the resistor string?
Feb29-12, 01:12 PM   #14
Recognitions:
Shouldn't the power supply ENTER the op-amp as opposed to EXIT from it?
Proof please!
Well, sum of all I entering that crossection I marked in red
3 -2 -I1 = 0
I1 = 1 mA
There you go...
LOL I didn't c that..sorry..ignore that part.
Feb29-12, 03:38 PM   #15
Recognitions:
It does.
The arrow indicates that the wire goes to a power supply.
It does not indicate the direction of the current.
The actual current flows away from the 25V power supply.
3 -2 -I1 = 0
I1 = 1 mA
There you go...
What happened to the current coming from the 25V power supply that is coming in through Rx?
How can we now that it's out there! ;)
Feb29-12, 04:36 PM   #16
Recognitions:
It does.
OOOOOhhhhhhhhh!!!! AHHHHHHA!!!
OH! OH!
Now I get it :)
It's kinda late now but i'll sit with it tomorrow trying t finalize my results based on this new evidence!
Well, it just says "Or take it"
Or being my name. Telling me that I should take this exercise and try to solve it. He just put the "e" in front of the "k" by accident :)
Feb29-12, 05:05 PM   #17
Recognitions:
Or take it!
Yes, I think I understand now what he meant. ;)
New Reply
Thread Tools
Similar Threads for: What kind of op-amp is that?
Thread Forum Replies
What kind of op-amp is that? Introductory Physics Homework 63
What kind of ODE is this? Differential Equations 1
What kind of job can get with........ Academic Guidance 6
What kind of a bomb? answer:the exploding kind. Special & General Relativity 9
What kind of job? Introductory Physics Homework 1
