Thermo - Prove that a rapid chemical reaction is irreversible.
The discussion focuses on proving the irreversibility of rapid chemical reactions, specifically through the example of methane combustion in a rigid container. The combustion reaction, represented as CH4 + 2O2 → CO2 + 2H2O + Energy, illustrates that the products cannot spontaneously revert to reactants without external energy input. Key concepts include the definition of irreversibility, the role of energy in chemical reactions, and the implications of conducting the reaction in a rigid container, which maintains constant volume and contributes to the irreversibility of the process.
  • Understanding of chemical reaction dynamics
  • Familiarity with the concept of irreversibility in thermodynamics
  • Knowledge of combustion reactions and their energy profiles
  • Basic principles of thermodynamic systems, particularly rigid containers
  • Study the laws of thermodynamics, focusing on the second law and its implications for irreversibility
  • Explore the concept of energy input required for reversing chemical reactions
  • Investigate the effects of pressure and temperature changes in rigid containers during chemical reactions
  • Learn about other examples of irreversible processes in thermodynamics, such as friction and unrestrained expansion
Chemistry students, engineering students, and professionals in thermodynamics or chemical engineering who are interested in understanding the principles of irreversible chemical reactions and their practical implications.
JJBladester
Show that processes involving rapid chemical reactions are irreversible by considering the combustion of a natural gas (e.g. methane) and air mixture in a rigid container.
[tex]Q_{in}+W_{e,in}-W_{b}=\Delta U+\Delta KE+ \Delta PE[/tex]
I know that an irreversible process is one that, when reversed, have some effect on the surroundings. Common irreversibilities are friction, unrestrained expansion, mixing of two fluids, heat transfer across a finite temperature difference, electrical resistance, inelastic deformation of solids, and chemical reactions.
This problem deals with the mixing of two fluids. Does it also deal with unrestrained expansion?
The problem says that the chemical reaction is "rapid" which immediately sets off the idea of irreversibility, and it also says the combustion happens in a "rigid" container which means the total volume inside the container never changes.
I know that combustion causes temperature and pressure to increase.
The heat produced by the gas during combustion equals the amount of work it would require to put the surroundings back to their original state, right?
How do I put all of these thoughts into a statement proving the irreversibility of combustion in a rigid chamber?
There were replies to my original post, but here is some light on the situation for all you struggling engineering students:
Combustion Reaction:
[tex]CH_4+2O_2 \to CO_2+2H_2O+Energy(Heat)[/tex]
methane + oxygen yields carbon dioxide + water + energy (heat)
The → symbol in this reaction indicates that the combustion reaction is irreversible. In other words, the CO2 + 2H2O created in the reaction do not spontaneously turn back into methane and oxygen.
To reverse the reaction and cause the carbon dioxide and water to turn back into methane and oxygen, energy input would be required. Thus, the chemical reaction is irreversible.
Only reversible processes can return to their original states without energy input from their surroundings.
  • · Replies 21 ·
