Norm Verification for Vectors in R^2
The discussion revolves around determining whether two functions defined on the vector space R² qualify as norms. The functions in question are ||x||_# = |x₁| + 2|x₂| and ||x||₃ = 3|x₁|. Participants are tasked with verifying the axioms of a norm or providing counterexamples if they do not satisfy the criteria.
  • Participants discuss the definition of a norm and the necessary conditions that must be satisfied. There are inquiries about how to verify each axiom and whether specific values of x₁ and x₂ affect the validity of the axioms. Some express confusion about the implications of absolute values and the generality required in the proofs.
The conversation is ongoing, with participants seeking clarification on how to approach the verification process. Some have offered guidance on structuring arguments, while others are still grappling with the definitions and requirements of norms.
Participants note the need for clarity in definitions and the importance of generalizing statements to cover all cases in R². There is also a recognition of the potential for misunderstanding the axioms due to the nature of absolute values.
bugatti79
Consider the vector space R^2, Decide whether or not the following are norms defined on R^2. If they are, verify all axioms of a norm, if not, demonstrate by counter example some axioms which fails. For x=(x_1,x_2) in R^2
(i) || ||_#: R^2 defined by ||x||_#=|x_1|+2|x_2|
(ii) || ||_3:R^2 defined by ||x||=3|x_1|
How do I decide whether or not the above are norms on R^2?
What is the definition of a norm?
Definition of a norm is a norm on a vector space V is a function || ||: V m to R satisfying for x,y in V and for all scalar alpha the following
1) ||x||>=0
2)||x||=0 iff x=0
3)||aX||=|a|||x||
4) The triangle in equality
But what do I need to do to decide whether or not they are norms?
Does each of your two norms satisfy all four requirements in the definition above? If so, it's a norm. If not, it isn't.
but how does one check this?
I mean we don't know the value of x1 and x2, they could both be easily less than 1 and hence it wouldn't satisfy axiom 1?
The value of x1 and x2 could both be 0 and then axiom 2 is satisfied.
I don't know how to argue axiom 3 and 4...?
If it is a norm, how does one 'verify' it?
thanks
Any tips on this guys? Thanks
What do you mean? You just do. Say something like "let x be an arbitrary member of ℝ2" and then use the definition of the function that may or may not be a norm to see if it satisfies the first condition. If it's satisfied, then you move on to the second condition. If it looks like it's not, you try to find an example that proves that it's not satisfied.
I don't know what you're talking about here. Both of the functions you mentioned in your post very obviously satisfy axiom 1.
Axiom 2 is a "for all" statement, so you can't test it with one specific value of x, unless you're trying to prove that it's not satisfied. Note that all of the axioms are "for all" statements.
Why would being "less than 1" contradict "greater than or equal to 0"?
I mean we don't know the value of x1 and x2, they could both be easily less than 0 and hence it wouldn't satisfy axiom 1?
thanks
Sorry, this is a typo, I meant the value of x could be less than 0 not 1...and then it would contradict axoim 1..?
Assuming that you made another mistake here, and meant x_1 and x_2 when you said "x", then no, it wouldn't, because of the absolute value signs in the definitions. If you had been working with another definition, one that implies that there's an x such that ##\|x\|<0##, then the axiom is violated, but that doesn't make it harder to check if the axioms are satisfied. It makes it easier, because then all you have to do is to find that x, show that ##\|x\|<0##, and you're done.
1) ||x||>=0
2)||x||=0 iff x=0
3)||aX||=|a|||x||
Ok here's my attempt,
1) since x=(x1,x2) is in R^2 and we know |x1|>=0 and |x2|>=0 implies ||x||>=0 for all x in R^2 hence N1 holds
2) ||x||=0 iff both x1=0 and x2=0, ie x=(0,0)=0 the zero vector implies N2 holds
3) ||a x || = |a| |x|
=|a|(|x1|+2|x2|)
= |a| |x1| + 2 |a| |x2| (all I am doing is throwing a on both side of equation so of course it holds, right?)
4) The triangle inequality is ||x+y|| <= ||x||+ ||y||
I don't know how to check this one...
Thanks
1. You can't say "Since x is in R^2" when you haven't even mentioned x before. You need to start with something like "Let x be an arbitrary member of ℝ2". You also need to make it absolutely clear what definitions you're using. I don't see anything that indicates which of the functions you're trying to prove something about.
2. What is x in the iff statement? Why does that statement hold. Which one(s) of the functions are you talking about?
3. This doesn't make any sense. The first equality is what you're trying to prove, except that the right-hand side should say ##|a|\,\|x\|##, not |a| |x|. You're obviously not allowed to use what you're trying to prove. The calculation you did after that adds nothing at all. You need to start with ##\|ax\|=\dots##, then use the definition, and end it with ##\dots=|a|\,\|x\|##.
You must always make it clear if your variables are part of "for all" or "there exists" statements, or if they are defined to represent some specific member of the set you're dealing with. You must always make it absolutely clear how you're using the definitions of the terms or symbols that you're trying to prove something about.
I am referring to part (i). I am not sure what the subscript 'hatch' or 'star' means
1) Since we are given that x=(x1,x2) is in R^2 and we have that ||x||_#=|x1|+2|x2|, then ||x||>=0 because we have that |x1| and |x2| are both >=0 implies ||x||>=0 for all x in R
2)||x||_#=0? We have ||x||=|x1|+2|x2|=0 iff |x1|=0 and |x2|=0 for all x in R
3) ||ax||_#=...? I didn't know one was not allowed use what we are trying to prove. Then what else can we do?
4) ?
Thanks
It's just a notation for that specific function.
This is OK, but don't say that you're given that x is in ##R^2##. You're not given an x, or any variable at all. You're just supposed to prove a statement of the form "For all v in ##R^2##, we have P(v)", where P(v) is a statement that involves v. In this case, P(v) is the statement "##\|v\|\geq 0##". This is how I'd do it:
Let ##x\in\mathbb R^2## be arbitrary. By definition of ##\|\ \|_{\#}##, we have
$$\|x\|_{\#}=\underbrace{|x_1|}_{\geq 0}+2\underbrace{|x_2|}_{\geq 0}\geq 0.$$
This is OK too. It's sufficient to say that since ##\|x\|_{\#}=|x_1|+2|x_2|##, it's obvious that ##\|x\|_{\#}=0## if and only if ##x=0##.
I answered that in my previous post, and I'm doing it again below.
bugatti79 said:
4) ?
Same idea as in all of these problems. Start by saying "Let ##x\in\mathbb R^2## be arbitrary". Then write down the left-hand side of the equality or inequality you want to prove. Then use the definition of ##\|\ \|_{\#}## and things you know about ##\mathbb R^2## until you end up with the right-hand side of the result you want to prove.
Fredrik said:
It's just a notation for that specific function. This is OK, but don't say that you're given that x is in ##R^2##. You're not given an x, or any variable at all. You're just supposed to prove a statement of the form "For all v in ##R^2##, we have P(v)", where P(v) is a statement that involves v. In this case, P(v) is the statement "##\|v\|\geq 0##". This is how I'd do it:
This is OK too. It's sufficient to say that since ##\|x\|_{\#}=|x_1|+2|x_2|##, it's obvious that ##\|x\|_{\#}=0## if and only if ##x=0##. I answered that in my previous post, and I'm doing it again below.Same idea as in all of these problems. Start by saying "Let ##x\in\mathbb R^2## be arbitrary". Then write down the left-hand side of the equality or inequality you want to prove. Then use the definition of ##\|\ \|_{\#}## and things you know about ##\mathbb R^2## until you end up with the right-hand side of the result you want to prove.
3) Let ## x \in \mathbb R^2.## By definition we have ##\|x \|_{\#} = \|x_1\|+2\|x_2\|##
##\|a x \|_{\#}=\|ax_1\| +2 \|ax_2\|=|a| ( |x_1|+2|x_2|)=|a| \| x \|_{\#} \forall a, x \in \mathbb R^2## N3 holds
4) Let ##y \in \mathbb R^2## where ## \|y\|_{\#}=|y_1|+2|y_2|##
Therefore ##\|x+y\|= |x_1|+2|x_2| + |y_1||+2|y_2|##
By definition of the inequality ##\|x+y\| \le \|x\|+\|y\|## we have
##\|x+y\|_{\#} \le |x_1|+2|x_2|+|y_1|+2|y_2|##
$$ \le \|x\|_{\#}+\|y\|_{\#} \forall x,y \in \mathbb R^2$$ N4 holds.....?
Tackle part 2 in same way?
Thanks
The first sentence should say "Let ##x\in\mathbb R^2## be arbitrary". The definition of ##\|\ \|_{\#}## tells us that ##\|x\|_{\#}=|x_1|+2|x_2|##.
This is mostly OK. The norm symbols after the first equality sign should of course be absolute value signs. a is not a member of ##\mathbb R^2##. This is what you should have said: For all ##a\in\mathbb R## and all ##x\in\mathbb R^2##, we have
$$\|ax\|_{\#}=\|(ax_1,ax_2)\|_{\#}=|ax_1|+2|ax_2|=|a|(|x_1|+2|x_2|)=|a|\|x\|_{\#}.$$ Note that the "for all" statement makes it unnecessary to also say "Let ... be arbitrary". The point of "let ... be arbitrary" statements is just that they enable us to break up a long sentence into several short sentences.
This is not what the definition of ##\|\ \|_{\#}## says. Try again. The proof should start like this: For all ##x,y\in\mathbb R^2##, we have
$$\|x+y\|_{\#}=\dots$$ Then you just use the definitions of x+y and ##\|\ \|_{\#}##, and whatever else you need.
$$\|ax\|_{\#}=\|(ax_1,ax_2)\|_{\#}=|ax_1|+2|ax_2|=|a|(|x_1|+2|x_2|)=|a|\|x\|.$$ Note that the "for all" statement makes it unnecessary to also say "Let ... be arbitrary". The point of "let ... be arbitrary" statements is just that they enable us to break up a long sentence into several short sentences.
Ok, thanks for the tips.
4) ##\forall x,y \in \mathbb R^2## we have ##x+y = x_1+2x_2 +y_1 +2y_2## therefore
##\|x+y|\_{\#}= |x_1|+2|x_2| +|y_1|+2|y_2|## but by definition of triangle inequality we have
##\|x+y\|_{\#} \le |x_1|+2|x_2|+|y_1|+2|y_2| \le \|x\|_{\#}+\|y\|_{\#}##...?
Surely, you must have meant to put something else on the right-hand side. The left-hand side is a member of ℝ2, and the right-hand side a member of ℝ.
This is wrong. The right-hand side is equal to ##\|x\|_{\#}+\|y\|_{\#}##, but it's certainly not true that ##\|x+y\|_{\#}=\|x\|_{\#}+\|y\|_{\#}## for all x,y in ℝ2. For example, when x=(0,1) and y=(0,-1), we have ##\|x+y\|_{\#}=0## and ##\|x\|_{\#}+\|y\|_{\#}=4##.
Fredrik said:
Surely, you must have meant to put something else on the right-hand side. The left-hand side is a member of ℝ2, and the right-hand side a member of ℝ.This is wrong. The right-hand side is equal to ##\|x\|_{\#}+\|y\|_{\#}##, but it's certainly not true that ##\|x+y\|_{\#}=\|x\|_{\#}+\|y\|_{\#}## for all x,y in ℝ2. For example, when x=(0,1) and y=(0,-1), we have ##\|x+y\|_{\#}=0## and ##\|x\|_{\#}+\|y\|_{\#}=4##.
4) ##\forall x,y \in \mathbb R^2## and ##x_1, y_1 \in \mathbb R##
we have ##x+y = x_1+2x_2 +y_1 +2y_2## ...?
Ok,so basically this question is not a norm in R^2 because axiom 4 does not hold. You have demonstrated that by counter example. but how do you know that axoim 4 does not hold without having to play around with actual values of x and y to test it?
No, Fredrik gave a counterexample to the equality. That doesn't mean that axiom 4 doesn't hold.
Are you just guessing now??
No, we don't. The left-hand side isn't even in the same set as the right-hand side (as I have already explained).
As micromass said, I only proved that it's not the case that ##\|x+y\|_{\#}=\|x\|_{\#}+\|y\|_{\#}## for all ##x,y\in\mathbb R^2##. You still have to determine if ##\|x+y\|_{\#}\leq\|x\|_{\#}+\|y\|_{\#}## for all ##x,y\in\mathbb R^2##. (Since 0≤4, my choice of x and y doesn't contradict this inequality).
If you mean that [itex]x= <x_1, x_2>[/itex] and [itex]y= <y_1, y_2>[/itex] then you should say that. Also, the result would be [itex]x+ y= <x_1+ 2y_1, x_2+ 2y_2>[/itex].
The first sentence was fine as it was.
No, I was just building up the equations bit by bit and then convert it into a norm (putting it inside the vertical brackets as shown on the following line of that thread) and then test it. Obviously I am wrong.
"we have ##x+y = x_1+2x_2 +y_1 +2y_2## ...?"
I don't understand why the LHS would not be = the RHS when I specify for the LHS that x,y are in R^2 and for the RHS x1 and y1 are in R.
I have an example where the triangle inequality is tested for a taxi cab norm ie || ||_1 and I understand it but I don't know how to do it for a || ||_#...?
Because you can't compare two things that aren't in the same space. A vector in R2 can't possibly be equal to a scalar. The two things aren't comparable.
Yes, it's OK to say "Let ##x\in\mathbb R^2##" instead of the more precise "Let ##x\in\mathbb R^2## be arbitrary" or the even more precise "Let x be an arbitrary member of ##\mathbb R^2##". When the proof is written by someone who understands proofs, and is read by someone who understands proofs, the statement "Let ##x\in\mathbb R^2##" will be interpreted as what it really is: A way to break up a long "for all" statement into several sentences. If you had started a proof with "Let ##x\in\mathbb R^2##" in a thread where you're discussing something with me, I wouldn't have said anything.
However, a person who doesn't understand these things, can, in my opinion, never put too much effort into improving the clarity of the proofs he's writing. I suggested that he should change the opening sentence because I strongly doubted that he understood the significance of what he wrote. In my experience, one of the most common mistakes that people make when they're just getting started with proofs is that that they fail to make it clear if their variables are part of "for all" or "there exists" statements.
An equality sign means that what you have on the left is the same thing as what you have on the right, not just that they're related in some unspecified way.
Maybe an example can make it even clearer. When x=(1,1), y=(1,0). We have x+y=(2,1) and ##x_1+2x_2+y_1+2y_2=1+2·1+1+2·0=4##. So in this case, your equality says (2,1)=4. This is obviously incorrect. Even if x and y have values such that the equality says (0,0)=0, where each 0 denotes the additive identity (the "zero") of ℝ, the equality is still incorrect, because even though (0,0) and 0 are both the additive identities of the vector spaces they are members of (ℝ2 and ℝ) respectively, they are members of different sets. (0,0) is an ordered pair of real numbers, while 0 is a real number, so you can never put an equality sign between them. (It is however OK to write (0,0)=0 if it's clear from the context that the 0 on the left denotes the additive identity of ℝ and the 0 on the right denotes the additive identity of ℝ2).
I have already told you:
If you keep asking yourself "how is this thing defined" at each step, you shouldn't have any problems with this. You can't just write things down that have nothing to do with the definitions. When you prove something, you always have to look for ways to use the definitions. A "proof" that doesn't use the definitions of the terms and symbols that are part of the statement is never correct.
I have mulled over all the threads and I'm afraid I don't see any light. I don't know how to proceed further. Its simple I know but I don't see it...
What is the first step that you're not 100% sure about? Do you know the definition of x+y? If yes, then why not use it? Then use the definition of ##\|\ \|_{\#}##. After that you're almost done.
