Integrating Trigonometric Functions with Powers
  • Thread starter Thread starter Kuma
    Integral
The discussion revolves around finding the integral of the function sin^3 t + t + cos^2 t from 0 to 2pi, focusing on the integration of trigonometric functions with powers.
  • Participants discuss converting sin^3 t using identities and question if there are simpler methods for evaluation. Some suggest considering the properties of the function over the given interval without direct integration.
There is an ongoing exploration of identities and properties of the functions involved. Some participants have noted that sin^3 t evaluates to zero over the interval, while others are seeking clarification on the implications of this observation and the identities that could simplify the problem.
Participants are considering the periodic nature of the functions and the implications of integrating over a full period. There is mention of using the half-angle identity and the double angle formula for cosine, but no consensus on a single approach has been reached.
Kuma
I want to find the integral from 0 to 2pi of
I could convert sin^3 t to sin t (sin^2 t) and then use the identity 1 - cos 2t/2 and same for cos^2 t but I was wondering if there is a less messy way to evaluate this.
Since your limits are 0 to 2pi if you clever you should be able to come up with an argument about the value of the sin(t)^3 part without integrating it. But you could also use another even simpler identity for sin(t)^2.
Ah, I see that it is 0 for sin^3 t, does this hold for any period of 2pi for sin^3? Also what is the other identity that I could use? I thought it would just be the half angle identity.
Integrating the t term is trivial.
The cos^2 term can be handled with the double angle formula for cosine.
The sin^3 term can be immediately reduced to zero by sketching the curve for y = sin^3x and observing that it's an odd periodic function. It applies for any *even* multiple of pi at both upper and lower bounds.
sin(t)^2=1-cos(t)^2.
