New Reply
Op-amp true or false
Share Thread Thread Tools
Feb29-12, 04:13 PM   #1
Recognitions:
Gold Membership Gold Member
True or false:
In the following circuit no current flows through R since Vout equals Vin.
I say TRUE because it's the same as Voltage follower
My classmate disagrees with me, says it's false, saying "if vout passes through a resistor, then the voltage on that input is lower than vout"
Who's right?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb29-12, 04:17 PM   #2
Mentor
It's an underdefined problem as stated.
Are you assuming an "ideal" opamp? Or one that has input bias currents? And you should probably label the + and - inputs of the opamp, although that wouldn't change the answer to the problem.
Feb29-12, 04:29 PM   #3
Recognitions:
Homework Helper Homework Help
I believe you are right. :)
Btw, Vout does not "pass" through a resistor.
A "current" passes through a resistor, and only if the voltages on both sides of the resistor are different.
In this case those voltages are the same.
However, I am assuming the op-amp has its + and - inputs configured like a voltage follower.
If they are reversed, the circuit is unstable and Vout will either go up to Vcc+ or go down to Vcc-.
Either way, there will no (significant) current flowing through the resistor since the op-amp has a resistance that is near infinity.
EDIT:
Quote by berkeman View Post
What do you mean by "underdefined"?
Feb29-12, 04:41 PM   #4
Recognitions:
I didn't compose the questions, I didn't draw the image but took it directly from the source. I was confused about the lack of + and - inputs myself. And they didn't say if it's ideal or not, HOWEVER in our course IIRC we were told to assume all Op-Amps are ideal.
As I suspected! Thank you
So, if it's an inverter though, the it's no longer a Voltage follower, so I can't use the same Vout = Vin law. That part I understand, though I wouldn't be sure what to make of it if the inputs were indeed reversed.
Feb29-12, 05:03 PM   #5
Recognitions:
Quote by Femme_physics View Post
In this case the circuit is not configured like the way an inverting amplifier or a voltage follower should be configured, so you should not use their behavior.
To figure out what the circuit does, you need to apply the basic op-amp law that says:
$$V_{out} = (V_+ - V_-) A_{OL}$$
where ##A_{OL}## is the so called open-loop-gain which is typically about 1000000 and where ##V_{out}## is limited to the range Vcc- to Vcc+.
From there you can try and "solve" the circuit.
After solving the circuit, you should consider what would happen if ##V_{in}## would rise just the tiniest fraction, say ##10^{-10} V##.
Either the circuit "pushes back" or it "diverges" to another solution where ##V_{out}## is either Vcc+ or Vcc-.
Feb29-12, 11:56 PM   #6
Recognitions:
I'll make sure I have this printed for reference. Thanks a lot Klaas! :)
Mar1-12, 02:49 AM   #7
Recognitions:
I have another question for true and false.
For an ideal operative amplifier there's infinite resistance at the entrance and an infinite amplification in an open circuit
I answered True, because I know the first sentence is true, but what is it about infinite amplification in an open circuit? I thought amplification is limited to the formulas ( Vout = ...) and the parameters of the op-amp. I didn't think it can ever get "infinite".
Mar1-12, 04:26 AM   #8
Recognitions:
Yes, an ideal op-amp does have infinite amplification.
The formula ##V_{out}=(V_+ - V_-) A_{OL}## gives the amplification.
In a real-life op-amp the amplification ##A_{OL}## is about 1000000.
In an ideal op-amp it is infinite.
Mar1-12, 05:58 PM   #9
Recognitions:
An ideal op amp has zero offset voltage, zero offset current, zero bias currents, infinite gain, zero output impedance. So your answer is correct. Why? Well ...
Zero bias current → zero current thru R, therefore zero voltage across R, therefore output = - input.
And since + input = - input, output voltage = Vin. So it's a voltage follower.
Mar1-12, 06:13 PM   #10
Mentor
Quote by rude man View Post
And zero cost!
Mar1-12, 06:15 PM   #11
Recognitions:
And zero cost!
Doesn't that depend on your point of view?
Since I'm producing ideal op-amps (virtually) I'm charging an infinite cost. ;)
Mar1-12, 06:33 PM   #12
Recognitions:
And zero cost!
Thass' right! I once had a prof who made up a table of ideal parameters and that was his entry too!
New Reply
Thread Tools
Similar Threads for: Op-amp true or false
Thread Forum Replies
Another True False Introductory Physics Homework 15
True or false: If it's true, give an example. If it's false, prove it. Calculus & Beyond Homework 3
true or false/correct if statement is false help Biology, Chemistry & Other Homework 2
I can't figure out if this statement is true or false, i said false Calculus & Beyond Homework 4
True or false General Astronomy 8
