| New Reply |
Gravitational Potential Energy, Elastic Potential Energy, and Kinetic Energy |
Share Thread | Thread Tools |
| Mar1-12, 07:25 AM | #1 |
A 4.0 kg mass is pressed down on a vertical spring of spring constant 400 N/m, compressing it to 0.250 m. After it is released, the amount of kinetic energy this mass would have when it leaves the spring is ___. 2. Relevant equations mgy(final) + 1/2 kx^2 (final) + 1/2 mv^2 (final) = mgy (initial) + 1/2kx^2 (initial) + 1/2 mv^2 (initial) 3. The attempt at a solution Ok so I think what I'm solving for is 1/2 mv^2 (final) (4.0 kg)(9.8m/s^2)(0m) + 1/2 (400 N/m)(0m)^2 + 1/2(4.0 kg)(v)^2 = (4.0 kg)(9.8 m/s^2)(-0.250 m) + 1/2(400 N/m)(-0.250m)^2 + 1/2(4.0 kg)(0 m/s)^2 That was sort of long so to simplify it a bit: 1/2(4.0 kg)(v)^2 = (4.0 kg)(9.8m/s^2)(-.250m) + 1/2(400 N/m)(-0.250m)^2 + 1/2(4.0 kg)(0 m/s)^2 My main concern: My "x" and "y" are the same. Is that because it's a vertical spring? I'm calling the end of the release x=0 m and y=0 m and the compression -0.250 m. |
| Mar1-12, 08:59 AM | #2 |
Recognitions:
you have done it all correctly. Technically speaking, x is the displacement from the equilibrium point. So you can think of it as Δx = x2-x1, where the x1 is the equilibrium point. We also know that the displacement Δx is purely vertical, so what is the (nice and simple) relationship between Δx and Δh?
| Mar1-12, 09:37 AM | #3 |
Ok, so Δx and Δh in this case are the same; that makes sense.
| Mar1-12, 12:19 PM | #4 |
Recognitions:
yep, that's right. Often you'll find that its the change in height that is important in questions with uniform gravity.
| New Reply |
| Thread Tools | |
Similar Threads for: Gravitational Potential Energy, Elastic Potential Energy, and Kinetic Energy
| Ballistic Pendulum - Kinetic Energy vs Gravitational Potential Energy | General Physics | 13 | ||
| Finding x when Elastic Potential Energy equals Kinetic Energy | Introductory Physics Homework | 3 | ||
| Kinetic energy and gravitational potential energy questions | Introductory Physics Homework | 3 | ||
| Potential Elastic Energy & Kinetic Energy | Introductory Physics Homework | 6 | ||
| Transformation of Kinetic and Gravitational Potential Energy:Conservation of Energy. | Introductory Physics Homework | 9 | ||
