Charged particles in parallel magnetic fields
Charged particles experience deflection in magnetic fields according to the right-hand rule, represented mathematically as qV x B. When the magnetic field lines are parallel to the velocity of the charged particle, the cross product becomes zero, resulting in no deflection. Therefore, a charged particle will not be deflected if its velocity is aligned with the magnetic field lines.
  • Understanding of the right-hand rule in electromagnetism
  • Familiarity with vector mathematics and cross products
  • Knowledge of charged particle dynamics in magnetic fields
  • Basic principles of electromagnetism
  • Study the implications of the Lorentz force in varying magnetic field orientations
  • Explore the behavior of charged particles in non-uniform magnetic fields
  • Learn about applications of charged particle deflection in devices like cyclotrons
  • Investigate the effects of electric fields on charged particles in conjunction with magnetic fields
Students and professionals in physics, particularly those focused on electromagnetism, as well as engineers working with charged particle systems and magnetic field applications.
Northprairieman
If a charged particle passes through a magnetic field it will be deflected according to the right hand rule, i.e. VxB.
What if the magnetic field lines are parallel to the velocity of the particle? Will the particle still be deflected?
Hi Northprairieman! :smile:
Nope. qVxB = 0: the force is zero. :wink:
  • · Replies 17 ·
