How Much Power Should My Wind Turbine Generate to Effectively Charge a Battery?
The discussion revolves around determining the appropriate power output for a small wind turbine designed to charge a battery. Participants explore the relationship between generator specifications, turbine design, wind speed, and the effects of torque on power generation. The scope includes theoretical calculations, practical design considerations, and efficiency factors.
  • Homework-related
  • One participant states that their generator is rated at 10W but questions how much power the wind turbine needs to generate to achieve this output, considering factors like torque and wind speed.
  • Another participant critiques the clarity of the initial post, asking for more details about the relationship between torque and power generation.
  • A participant mentions that at 2800 RPM and a wind speed of 15 m/s, a turbine blade size of 0.13m x 0.05m could theoretically produce 10W, but expresses uncertainty about the impact of torque on actual output.
  • A later reply provides a formula relating power, shaft speed, and torque, highlighting the importance of conversion efficiency and potential power losses in the system, suggesting that 50 to 60W from the wind may be necessary to achieve 10W electrical output.
  • One participant suggests looking at DIY wind turbine resources for practical examples and tested designs.
Participants express uncertainty regarding the exact power requirements and the effects of torque on generator output. There is no consensus on the specific calculations or design parameters needed to achieve the desired power output.
Participants mention various factors affecting power generation, including efficiency losses in the generator and transmission system, but do not resolve the specifics of these calculations or assumptions.
hollyhiccups
I am making a small wind turbine using a generator to charge a battery.
I have chosen a generator in relation to the battery and ultimate output requirements of the LEDs.
However - I need to determine the amount of power I need to put generate for the system to work effectively.
The generator is rated at 10W. However I understand that due to Torque... To actually achieve this, the turbine design (and wind speeds) will need to produce more Watts than this.
But just how much is what I struggling with - is there a formula to use?
Theoretically achieving an RPM of 2800 and there is a constant wind speed of 15 m/s.
Many thanks :)
There are a lot of numbers in your post, but not much information as to what you know, what you don't know, etc.
You say, "The generator is rated at 10W. However I understand that due to Torque... " Well, "due to torque, what?" Are you making a statement, asking a question, or just fading out?
You also say, "Theoretically achieving an RPM of 2800 and there is a constant wind speed of 15 m/s." This is not a sentence; there is no verb. Would you care to tell us what you had in mind here?
In theory my generator will achieve 2800 rpm.
At this speed the generator I am running will power 10W.
I need to design the wind turbine that will run with this generator to achieve 10W.
With wind speeds of 15m/s and an rpm of 2800 a turbine blade size of 0.13m x 0.05m would produce 10W.
However - from my limited understanding - Torque will mean that designing a turbine to produce 10W will not result in a 10W output from my generator.
How does Torque relate to this? Is there any equation? Any information or knowledge would be appreciated. :)
That is a whole lot better.
Power (watts) = ω T
where
ω = shaft speed (rad/s) = 2 π (rpm)/60
T = torque (N m)
There is also the matter of conversion efficiency. Ten watts of mechanical power into the generator will not give you 10 w electrical output. It depends on the design of your generator as to what the efficiency actually is.
There are also efficiencies to consider in the transmission between the turbine and the generator. Generally speaking, there is some power lost at every step, so part of the answer is to minimize the number of steps, and the other part is to minimize the losses per step.
It would not be surprising if you needed 50 or 60 w of power from the wind to get 10 w electrical output.
  • · Replies 33 ·
20K
