Analytic functions on simple connected region (complex analysis)
The problem involves analytic functions f and g defined on a simply connected domain Ω, with the condition that f²(z) + g²(z) = 1 for all z in Ω. The goal is to demonstrate the existence of an analytic function h such that f(z) = cos(h(z)) and g(z) = sin(h(z)).
  • Participants discuss the implications of the equation f² + g² = 1 and explore the definition of H as a composition of analytic functions. There is an attempt to connect the definition of H to the existence of an antiderivative h. Some participants express uncertainty about how to show the relationships between f, g, and h without circular reasoning.
Some participants have suggested using a theorem regarding analytic and non-zero functions in simply connected domains to simplify the problem. Others are exploring the implications of defining h in terms of H and the exponential function, indicating a productive direction in the discussion.
There is mention of constraints related to the continuity of the logarithm function and the avoidance of zero in the domain, which are relevant to the problem's setup.
lonewolf5999
Here's the problem:
Let f and g be analytic functions on a simply connected domain Ω such that f2(z) + g2(z) = 1 for all z in Ω. Show that there exists an analytic function h such that f(z) = cos (h(z)) and g(z) = sin(h(z)) for all z in Ω.
Here's my attempt at a solution:
f2 + g2 = 1 on Ω, so (f+ig)(f-ig) = 1 on Ω, so neither of those expressions are ever 0 on Ω. Then, defining H = (1/i)(f' + ig')/(f+ig), H is a composition of analytic functions, and hence is analytic on Ω, a simply connected domain. Therefore H has an antiderivative h on Ω.
Now I'd like to argue that cos(h(z)) = f(z) and similarly for g(z), but it's not clear to me how to do this. If we integrate H directly (I know this is not allowed, but supposing it is), we get something like h = (1/i) log(f+ig), so that exp(ih) = exp(log(f+ig)) = f+ig, but on the other hand exp(ih) = cos(h) + i sin(h), which is more or less what I want. I've checked that cos(h(z)) = f(z), the other equality follows, and conversely as well, so my problem is in showing that one of those equality holds without using the other.
I'd really appreciate any help on how to proceed from my definition of H to argue that its antiderivative h satisfies f(z) = cos (h(z)) and g(z) = sin(h(z)). Thanks in advance!
lonewolf5999 said:
Here's the problem:
There is a theorem that if a(z) is analytic and nonzero in a simply connected domain then there is an analytic function b(z) such that a(z)=exp(b(z)). That's what you are looking for isn't it?
I can't find that theorem in my book, but if I use it, the answer comes out very easily: since f+ig is analytic and non-zero on Ω, let H be an analytic function such that f+ig = exp(H), then define h = iH, and I can show that f = cos(h), g = sin(h). I guess I'll just prove it for my problem. Thanks for the help!
It's really pretty easy to see if you know how the log function works. As long as your domain stays way from zero and doesn't contain any loops around zero, you can define a continuous log function on the domain.
  • · Replies 17 ·
