| New Reply |
Proving that apparent weight is 5 times actual weight (no numbers) |
Share Thread |
| Mar4-12, 12:55 PM | #1 |
Without numbers, identify how you could find the apparent weight of motorcycle to be 5 times that of the actual weight. The motorcycle is going up a loop the loop with a velocity of v. 2. Relevant equations Fnet = mv^2/r Fg = mg 3. The attempt at a solution Fnet = mv^2/r Fg + Fn = mv^2/r Fn = mv^2/r - Fg Fn = mv^2/r - mg Fn = mv^2/r - mgr/r Fn = (mv^2 - mgr)/r I have no idea of this is right or if I'm completely misinterpreting the question. |
| Mar4-12, 01:34 PM | #2 |
This seems to be an open ended question and does not require you to consider a specific position for the bike.May I suggest that you consider the bike at its bottom most position(that's where its apparent weight will be biggest for a constant speed).What are the two relevant forces on the bike,in what directions do they act and what is an expression for the resultant force?
| Mar4-12, 01:37 PM | #3 |
hi testme!
![]() start by deciding: at which point in the loop is the apparent weight greatest? |
| Mar4-12, 01:38 PM | #4 |
Thats what I was assuming. The bike was at the bottom, the two forces acting upon it are the normal force (apparent weight) and the gravitational force (actual weight).
using that I came up with the equation Fnet = mv^2/r Fg + Fn = mv^2/r Fn = mv^2/r - Fg Fn = mv^2/r - mg Fn = mv^2/r - mgr/r Fn = (mv^2 - mgr)/r Though I'm not sure if that'd be the right way to find out. Also, that value would have to be 5 times your mass times gravitational acceleration. When the questions asks without numbers they mean as in no numbers given, so just theoretically the proccess. That's what my teacher said. |
| Mar4-12, 01:47 PM | #5 |
At the bottom the normal force(apparent weight) acts upwards and the weight acts downwards.
| Mar4-12, 01:47 PM | #6 |
words only:
"as soon as it goes into the loop, if will have a centripetal acceleration which can only be supplied by an increased normal force, which (for fixed v) will be proportional to … , which can be made large enough by making … sufficiently … " |
| Mar4-12, 01:55 PM | #7 |
Fnet = mv^2/r
-Fg + Fn = mv^2/r Fn = mv^2/r + Fg Fn = mv^2/r + mg Fn = mv^2/r + mgr/r Fn = (mv^2 + mgr)/r Would that be it then? |
| Mar4-12, 01:58 PM | #8 |
Looks good but remember Fn=5mg
| Mar4-12, 02:01 PM | #9 |
Would it be fine that we find Fn using that and then we multiply Fg we would find by 5 at the very end?
| Mar4-12, 02:07 PM | #10 |
Fg is the "true weight" of the bike and that remains constant.What you are finding is an equation giving the necessary speed(v) for a given radius r for the bike to have an "apparent weight"(at the bottom) of 5mg.
| Mar4-12, 02:19 PM | #11 |
I get that, but what I mean is does it matter if I divide Fn by 5 at the end or multiply Fg by 5? Could I just say 5Fg must equal Fn or Fn/5 must equal Fg for this to be true?
| Mar4-12, 03:22 PM | #12 |
I'm not sure that I understand you.At the bottom the resultant force is Fn-mg.
(Fn represents the apparent weight in other words the weight that would be measured,by say,a set of scales over which the bike rides). We can write: Fn-mg=mv^2/r If the apparent weight is to be 5 times the real weight then Fn=5mg so we can write: 5mg-mg=4mg=mv^2/r |
| Mar5-12, 07:34 AM | #13 |
Nevermind, I got my answer, thanks for the help!
| New Reply |
Similar discussions for: Proving that apparent weight is 5 times actual weight (no numbers)
| weight/apparent weight | Introductory Physics Homework | 2 | ||
| Apparent Weight help! | Introductory Physics Homework | 13 | ||
| Apparent Weight | Introductory Physics Homework | 11 | ||
| Apparent weight | Introductory Physics Homework | 2 | ||
| Apparent Weight | Introductory Physics Homework | 14 | ||
