| New Reply |
A Question About Weight and Pressure |
Share Thread |
| Mar4-12, 12:55 PM | #1 |
Hello there :) First I'm sorry for my English it might be kinda bad !
I Have a little question about Weight and Pressure, Hope this is the right place. ![]() Here in this image we have 3 samples, A, B and C. They are 3 different types of shapes fulled with a liquid (let's say water) Talking about the physical pressure on the bottom of every shape :- In Sample (A) we can see that Weight = Pressure. In Sample (B) we can see that Weight < Pressure. In Sample (C) we can see that Weight > Pressure. Where did we get the extra pressure in the sample (B) ? It's like we create that green area from nowhere! And where did the extra weight go in the sample (C) ? It's like we lost that orange area and it's nothing! Hope I can fine the answer, Thank you :) ! |
| Mar4-12, 01:00 PM | #2 |
Mentor
| Mar4-12, 01:14 PM | #3 |
Recognitions:
Weight and pressure are very different things. For starters, weight is a force and has units of Newtons. Pressure is a force per unit area and has units of N/mē. Weight only acts downward toward the center of the Earth. Pressure acts in all directions simultaneously.
Pressure is not like light intensity (energy/mē), either. If you increase the area on the bottom, the pressure at the bottom is spread over a larger area but it is not thereby diminished as light intensity would be if spread over a larger area. Consider a balloon. If you blow it up to a pressure of 1.1 atmospheres, then pump it up to 1.2 the balloon gets larger and the pressure is 1.2 on every bit of the larger surface area. |
| Mar4-12, 01:47 PM | #4 |
| Mar4-12, 01:51 PM | #5 |
Mentor
| Mar12-12, 12:11 PM | #6 |
Doc Al and Delphi51 Thank you for your helping.
but when I explained it that way to my teacher he said that its not exactly the right answer. I think he is looking for a really advance answer that explains it all. |
| New Reply |
Similar discussions for: A Question About Weight and Pressure
| Weight into air pressure | Introductory Physics Homework | 17 | ||
| Weight of Air Pressure.... | General Physics | 9 | ||
| Fluid, pressure and weight question | Introductory Physics Homework | 0 | ||
| Question about water weight and pressure | Introductory Physics Homework | 4 | ||
| Relation of Pressure and Weight of Air. | Introductory Physics Homework | 1 | ||
