Question regarding mutual inductance of two coil
The discussion revolves around the concept of mutual inductance between two coils, focusing on the calculation of flux linkage and its relationship with inductance and current. Participants are exploring the definitions and implications of these concepts in the context of their homework problem.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to clarify the concept of flux linkage and its calculation, with some questioning their understanding of the relationship between the number of turns in the coils and the resulting flux. There are discussions about the definitions and formulas related to inductance and flux linkage.
Some participants have provided insights into the definitions and calculations related to flux linkage, indicating a productive exchange of ideas. However, there is no explicit consensus on the correct approach, and multiple interpretations of the problem are being explored.
Participants are working under the constraints of homework guidelines, which may limit the depth of assistance they can receive. There is an emphasis on understanding the underlying concepts rather than simply obtaining answers.
Sanosuke Sagara
I have my question,solution and the problem I faced in the attachment that followed.Thanks for anybody that spend some time on this question.
Please , I really need someone help me figure out where I have done wrong.
I think you did everything correct. The flux linkage is: [tex]N\Phi[/tex] not [tex]\Phi[/tex] (this is only for 1 turn, not the entire coil). So for coil 1 you get:
[tex]N\Phi=100*(1.5*10^{-6})=150\mu WB[/tex]
and coil 2:
[tex]N\Phi=200*(9*10^{-8})=18 \mu WB[/tex]
I take it that you are having problems with the flux linkage questions because you seem to have figured out the induced voltages. You may want to ask some engineers about flux linkage. It is a concept used more in engineering, but I will give it a shot.
Flux linkage is a measure of how much magnetic field produced by the coil is enclosed by the coil windings. It seems to be a relationship between flux enclosed by the coil and the actual current - I think. Inductance expressed in terms of the actual current I is
(1) [tex]L = nB\cdot A/I[/tex]
where n is the number of windings, B the magnetic field in the coil and A the cross-sectional area.
The term [itex]\lambda = nB\cdot A[/itex] is called the flux linkage.
But since you are given L and I, you can work out flux linkage from (1).
Does that help?
AM
Thanks for your help ,Andrew Mason and learningphysics.I now can understand with the question already.
I think an easier way to answer part a) is just to use the definition of inductance.
[tex]L_1=N_1\Phi_1/I_1[/tex]
[tex]25*10^{-3}=100(\Phi_1)/6*10^{-3}[/tex]
[tex]\Phi_1=1.5*10^{-6}[/tex]
[tex]N\Phi_1=100(1.5*10^{-6})=150 \mu WB[/tex]
  • · Replies 16 ·
