New Reply
Simulating lateral accelerations in a fuel tank test
Share Thread
Mar5-12, 11:36 AM   #1
[b]1. The problem statement, all variables and given/known data[We have a 5 litre rectangular fuel tank which when full of fuel will weigh 3.7kg, I need to simulate the affect off the car pulling 1.5g in the corner by tilting the fuel tank on the lateral and longitudinal axis. What angle would be required to achieve the same affect as 1.5g in a corner
2. Relevant equations
[b]3. The attempt at a solution[I have tried working from inclined slope type problems in mechanics however this tends to have gravity as the resultant force , therefore the lateral force can't be 1.5g as then one side of the triangle would be larger than the hypotenuse.]
There are two videos which show the rough type of rig I'm creating.
http://www.youtube.com/watch?v=fv53RbvgfGc
Regards
Richard Nash
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar5-12, 11:46 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by Nash7 View Post
Regards
Richard Nash
Presumably you're just looking for the angle away from vertical of the net acceleration vector. If the 1.5 g acceleration is outward (horizontal) and the gravitational acceleration is always vertical, find the appropriate angle of the resultant.
New Reply
Similar discussions for: Simulating lateral accelerations in a fuel tank test
Thread Forum Replies
Lateral force of water on the walls of a tank Classical Physics 17
Fuel tank explosions in aircrafts Mechanical Engineering 10
Fuel pressure change in closed fuel tank General Engineering 9
Pressure on a lateral side of a tank General Physics 31
How bad do we need a pressurized fuel tank? Mechanical Engineering 34
