Find the absolute maximum for f(t) = -t^3 + 3t^2 + 400t + 5000
  • Thread starter Thread starter 939
    Absolute Maximum
The discussion revolves around finding the absolute maximum of the function f(t) = -t^3 + 3t^2 + 400t + 5000, specifically within the interval of t between 6 and 20. Participants are exploring methods to analyze the function's critical points and behavior using calculus.
  • Participants discuss the necessity of finding critical points by setting the derivative f'(t) = 0 and the potential use of the quadratic formula for this purpose. There is also mention of the second derivative and its role in determining the nature of critical points. Questions arise regarding the feasibility of finding absolute maximums and the implications of approximations in the context of the problem.
There is a productive exchange regarding the use of the quadratic formula to find local maxima and the importance of evaluating endpoints of the given interval. Some participants affirm the approach while others express uncertainty about the implications of the second derivative.
Participants note that the function's derivative is not easily factored, leading to discussions about the implications of approximations and the necessity of checking both critical points and endpoints within the specified domain.
939
Find the absolute maximum for f(t) = -t^3 + 3t^2 + 400t + 5000, t is between 6 and 20.
f'(t) = -3t^2 + 6t + 400
I know how to find this - when the function can be perfectly factored. Yet some problems occur here.
I normally factor to find minimum, but 400 divided by -3 = -133.33333~, meaning the answer will be approximate (technically) if I do that... Now the second derivative will come to something really easy, 6t+6... Can absolute maximums be found with the second derivative? If not, how can it be found here?
First, find any local maxima by setting f'(t) = 0. For your problem, use the Quadratic Formula to find zeroes. The second derivative can be used to determine whether critical points are maxima, minima, or inflection points.
A global max/min can occur and any of three places:
a) local critical points (at which f'(t) = 0)
b) points in the domain of f at which f' is undefined - not relevant for your problem
c) endpoints of the domain - very relevant for your problem
You're on the right track, but you need to set the derivative equal to zero to find a maximum. Even though it can't be easily factored, you can still use the quadratic formula to find your values of t. You'll use the second derivative to see if it's a maximum, minimum, or inflection point.
Remember that on a bounded interval you need to check the bounds to see if those are maxima too.
Thanks to both of you. Yes, the way to solve it was with the quadratic formula, 100%. My mistake :).
