New Reply
How to tell if a pair of functions are linearly dependent or linearly independent
Share Thread Thread Tools
Mar5-12, 06:32 PM   #1
Determine if the pair of functions given are linearly independent or linearly dependent on the interval 1<x<∞, and give a reason for your answer.
y1=|x| y2=-3x
2. Relevant equations
I'm pretty sure this has something to do with the Wronskian.
W(f,g)=fg'-f'g
3. The attempt at a solution
f=y1, g=y2
f'=1, g'=-3
I can assume that the derivative of the abs. value of x is just 1, because the question says that x is greater than 1, right?
So then W(f,g)=-3|x|+3x
can i assume x is positive again, so therefore the Wronskian is equal to zero? Would this then make my solution linearly independent?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar5-12, 06:37 PM   #2
Maybe I'm misunderstanding the question, but it seems to me that all you have to do is see whether they are linear combinations of each other. does y1(x) = a*y2(x) for all x in the domain, for some constant a?
Mar5-12, 07:41 PM   #3
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Technically just showing that the Wronskian is zero doesn't tell you the functions are linearly dependent. There are exceptions to that. Follow the suggestion 80past2 gave.
New Reply
Thread Tools
Similar Threads for: How to tell if a pair of functions are linearly dependent or linearly independent
Thread Forum Replies
Linear Algebra - showing sets are linearly independent/dependent Calculus & Beyond Homework 1
Linearly Independent/Dependent Calculus & Beyond Homework 4
Linear Algebra (Linearly Independent vs. Linearly Dependent) Calculus & Beyond Homework 10
How to show functions are linearly dependent? Calculus & Beyond Homework 9
Linearly dependent or independent functions? Calculus & Beyond Homework 6
