Special Relativity. How to use the Lorentz Transformation?
In summary, Stan and Mary are both at rest on the Earth and start their timers when Mary passes Stan. When Mary has traveled 0.900 * 10^8m according to Stan, the time according to Stan is 0.5 seconds. At this moment, according to Stan, Mary's timer reads 0.4 seconds, not 0.625 seconds as calculated using the Lorentz Transformation. This is because x does not equal 0, and at the instant Stan reads the time, Mary is not 0.900 * 10^8m away from Earth, but rather still on Earth. Therefore, the question should be interpreted as asking for the time according to Stan at the moment when Mary's timer
AlonsoMcLaren
90
γ
Stan is at rest on the Earth while Mary is moving away from the Earth at a constant speed
of 0.600c. Stan and Mary start their timers when Mary passes Stan (in other words, t = t' = x = x' = 0 at that instant).
(a) When Mary has traveled a distance of 0.900 *108m according to Stan, what is the time according to Stan?
(b) At the instant Stan reads the time calculated in part (a), what does Mary’s timer read?
(a) is simple. I got it correctly. t=x/V=0.5s
I got (b) wrong. I plugged in the Lorentz Transformation:
x=0
γ=1.25
V=0.600c
t=0.5s
t' =γ (t-Vx/c2) = 0.625 s.
But the answer is 0.4s, which claims that x=0.900 *108m, not 0.
However, at the instant Stan reads the time 0.5s from his clock, he and his clock are sitting on the earth, not 0.900 *108m away from earth. So I do not think that x=0.
The question should be interpreted as "At the instant Stan reads the time calculated in part (a), what does Mary’s timer read according to Stan?"
No, x ≠ 0. According to Stan, where is Mary at the moment in question?
1. What is special relativity?
Special relativity is a theory developed by Albert Einstein that describes the relationship between space and time, specifically for objects moving at high speeds. It explains how measurements of space and time can vary for different observers, and how the laws of physics remain the same for all inertial observers.
2. How does special relativity differ from classical mechanics?
Special relativity differs from classical mechanics in that it takes into account the effects of objects moving at high speeds, close to the speed of light. It also introduces the concept of spacetime, where space and time are not separate entities but rather interconnected.
3. What is the Lorentz transformation?
The Lorentz transformation is a mathematical formula used to describe how measurements of space and time change between two inertial reference frames that are moving relative to each other at a constant velocity. It is a key concept in special relativity and helps to explain phenomena such as time dilation and length contraction.
4. How is the Lorentz transformation used in special relativity?
The Lorentz transformation is used to calculate the effects of special relativity on measurements of space and time. It allows us to understand how these measurements change for different observers moving at different velocities, and how the laws of physics remain the same in all inertial reference frames.
5. What are some practical applications of special relativity and the Lorentz transformation?
Special relativity and the Lorentz transformation have several practical applications, including in the development of GPS technology, particle accelerators, and nuclear power plants. They also help to explain natural phenomena such as cosmic ray showers and the behavior of high-speed particles in space.
