Heat Convection through a Vertical Pipe
This discussion focuses on modeling the flow of steam through a vertical cylinder to determine the surface temperature as a function of the pipe's length. The user is attempting to apply a shell balance method but is confused about the convection terms and how to establish the temperature gradient due to convection. The analysis requires distinguishing between laminar and turbulent flow, emphasizing that it is not a straightforward application of equations. The referenced article provides additional insights into the topic.
  • Understanding of heat transfer principles, specifically convection and conduction.
  • Familiarity with fluid dynamics, particularly laminar and turbulent flow characteristics.
  • Knowledge of shell balance techniques in thermal analysis.
  • Experience with modeling steady-state processes in thermal systems.
  • Study the principles of heat transfer in vertical pipes, focusing on convection effects.
  • Learn about the differences between laminar and turbulent flow and their implications on heat transfer.
  • Explore shell balance methods in greater detail, particularly for fluid systems.
  • Review the referenced article on heat transfer in pipes for practical applications and examples.
Mechanical engineers, thermal system analysts, and students studying heat transfer and fluid dynamics will benefit from this discussion.
AstroWave
Hello everyone,
I am trying to model the flow of steam through a vertical cylinder. Ultimately I would like to find the surface temperature as a function of the length of the pipe. I am assuming the steam cools as it moves upward along the length of the pipe and it is a steady-state process, so T only varies with position (1-dimensional).
Doing a shell balance around a small portion of the pipe I am confused about the convection term entering in from the base and leaving through the top of the shell. I understand the cross sectional area concerning this convection term is the area of a circle. However, I am uncertain about how to determine the gradient for the surface temperature when all of the terms in the energy balance are due to convection.
I have seen the similar process done for a solid pipe (long fin) where there was conduction through the shell and convection out of the side. But I am confused by fluid motion inside the shell.
Any advice on this conceptually, or if you could recommend another approach, would be appreciated.
You have to determine whether you are dealing with laminar or turbulent flow to begin with. The analysis is not a plug into an equation and get the answer,
Consider this article:
http://people.msoe.edu/~kumpaty/courses/ME%20318/Week6_7.pdf
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 34 ·
