New Reply
Change in potential energy/work formula for electric charges.
Share Thread Thread Tools
Mar8-12, 01:27 AM   #1
I have the following formula on my formula sheet:
ΔU = U_a - U_b = q(V_a - V_b)
I was wondering if 'a' is final and 'b' is initial or is it the other way around? Also when I plug in my charge q into the formula, if it was a negative charge do I plug the negative sign into the formula? I realize that some formulas assume that you plug in the magnitude of the charge so I am not so sure about this formula... Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Mar8-12, 02:24 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
The change of potential energy from a to b is Ub-Ua=q(Vb-Va), but the work done by the electric field on a charge q when it moves from a to b is W(ab)=Ua-Ub. If the charge moves in free space the work done by the field increases its kinetic energy: Ub-UA=KE(b)-KE(a), which means that U+KE=const, conservation of energy.
Imagine that the (positive) charge moves across a resistor from a to b. The moving charge constitutes current; the current flows from positive to negative, in the direction of decreasing potential: I=(Va-Vb)/R, and the work done (and dissipated on the resistor) while q charge moves from a to b is q(Va-Vb). Va-Vb sometimes is called "voltage" or "potential drop". Ohm's Law means that Current=potential drop divided by resistance.
The charge q can be either positive or negative, but you can omit the sign when you are interested only in the magnitude of work .
ehild
New Reply
Thread Tools
Similar Threads for: Change in potential energy/work formula for electric charges.
Thread Forum Replies
Electric Potential Energy: Work Required to Move 3 Charges Out to Infinity Introductory Physics Homework 2
Work with Charges and Electric Potential Introductory Physics Homework 4
Potential Energy of Electric Charges Introductory Physics Homework 2
Electric Potential/Work - POint Charges on a Square Introductory Physics Homework 1
Expression for the change in potential energy of charges Advanced Physics Homework 0
