How Do You Determine Supremum and Infimum Without Graphing?
  • Context: Undergrad
  • Thread starter Thread starter elizaburlap
    Graphs Supremum
The discussion revolves around determining the supremum and infimum of sets without the aid of graphical representations. Participants explore methods for deriving these concepts, particularly in the context of more complex sets and sequences, and consider the implications of limit points and bounds.
  • One participant questions how to derive supremum and infimum without graphing, especially for complicated sets.
  • Another participant asks about finding upper and lower bounds for sets as a starting point.
  • Some ideas are proposed regarding limit points, suggesting that both the supremum and infimum (when finite) are limit points of a set, and referencing closed sets in this context.
  • A participant raises the challenge of extending the concepts to infinite cases, using the example of a sequence that converges to zero.
  • There is a clarification regarding the use of 'limit point' in relation to infinity, noting that in the extended reals, neighborhoods of infinity contain points of the set.
  • Suggestions for recognizing limits include analyzing the behavior of expressions as they approach infinity, considering oscillation or growth, and using trial-and-error to test potential supremum or infimum values.
Participants express various methods and ideas, but there is no consensus on a definitive approach to determining supremum and infimum without graphing. Multiple competing views and techniques are presented.
Limitations include the dependence on definitions of limit points and bounds, as well as the complexity of sequences and sets discussed. The discussion does not resolve how to handle cases where the supremum or infimum is infinite.
elizaburlap
In class, we have been introduced to the supremum and infimum concepts and shown them on graphs, but I am wondering how to go about deriving them, and determining if they are part of the set, without actually having to graph them- especially for more complicated sets.
Are you able to find "upper bound" and "lower bounds" for sets?
Some ideas:
Have you already seen limit points? If so, try showing that both the sup and the inf (when both are finite*) , are limit points of a set. Then look for a charcterization of closed sets in terms of limit points.
*This can be extended to the infinite case too, but let's start slowly.
How would you go about extending it to infinity?
In the text it has a few examples that span n from 1 to infinity.
Such as, an=n(-1)^n
I understand that it does converge, because an approaches 0 as n approaches infinity, but when the equations become more complicated, how to I recognise this without a graph?
Such as, an=n(-1)^n
I actually used 'limit point' here a little too losely (specially since ∞ is not a real number); what I meant is that , in the case the sup is ∞ , the values would become indefinitely-large. In the extended reals, every 'hood (neighborhood) of ∞ would contain points of the set.
To recognize/determine the limit, I would suggest looking at the expression and trying to understand what happens with it as you approach ∞. Does it oscillate, increase, etc. If you cannot tell right away, consider trial-and-error. Assume a certain value is the Sup (Inf) , and put it to the test. That is the best I got; I cannot think of any sort of algorithm. It just seems to come down to practicing.
  • · Replies 21 ·
  • · Replies 49 ·
  • · Replies 17 ·
