New Reply
Why does the Unit Circle work?
Share Thread
Mar9-12, 12:58 AM   #1
In my Trig class, we learned about the unit circle and its relationship to the various trig functions (sin, cos, etc.).
I am curious to know why the unit circle works the way it does, and the how it was "derived" so to speak.
More specifically, why does radius of the circle have to be 1 for the circle to work.
Please try to keep your explanations as mathematically friendly as possible, as I am only in precalculus.
Thank you
PhysOrg.com mathematics news on PhysOrg.com
>> Pendulum swings back on 350-year-old mathematical mystery
>> Bayesian statistics theorem holds its own - but use with caution
>> Math technique de-clutters cancer-cell data, revealing tumor evolution, treatment leads
Mar9-12, 01:00 AM   #2
All of those functions we're defined based on the unit circle. It works because we designed it to work.
Mar9-12, 02:33 AM   #3
Quote by Number Nine View Post
I think the sine was defined as the opposite side divided by the hypotenuse, in a right angled triangle. I'm pretty sure sin and cos were used before cartetsian coordinates.
Since the hypotenuse will be the radius of the unit circle, this has to be 1 to make the length of the side opposite to angle A equal to sin(A)
Mar9-12, 03:41 AM   #4
Quote by willem2 View Post
very sensible,,,
Thanks for the explanation,,,
Mar9-12, 06:21 AM   #5
The idea begins When Babylonians have developed a system for measuring angles "degree measure", They discovered some trigonometric theorems but not explicitly , and then the sin function was first developed in India . But trigonometry wasn't translated to Europe through the Hindus , but through Muslims " arab " . Islamic Arabian mathematicians had taken the ideas from the hindus and expanded them where they have known the six main trigonometric function , they were Calculating them using triangles . So the trigonometry was invented depending on triangles , but it was seen after that its relation with unit circle which willem2 had mentioned . All I can say you that with that curiosity and when you take integral Calculus , I advise you to read spivak's construction for trigonometric function which is even more rigorous than defining them in terms of unit circle , where you will see why .
Mar9-12, 01:01 PM   #6
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
if you are asking about the connection between the "circular" functions (sine and cosine as defined using the unit circle) and the "trigonometric functions) (sine and cosine as defined using right triangles), from a point, (x, y), on the unit circle, draw the line from (x, y) to (0, 0), the line from (x, y) to (x, 0), and the line from (x, 0) to (0, 0).
That gives a right triangle which has "near side" of length x, "opposite side" of length y, and hypotenuse of length 1. Therefore, [itex]sin(\theta)=[/itex]"opposite side over hypotenuse= y/1= y and [itex]cos(\theta)= [/itex]"near side over hypotenuse"= x.
(Since the angles in a triangle can only be between 0 and 90 degrees, we really have to assume that (x, y) is in the first quadrant. The circle definition extends that to all real numbers.)
New Reply
Tags
trig equation, unit cirlce
Similar discussions for: Why does the Unit Circle work?
Thread Forum Replies
unit Joule is the unit of work and of kynetic energy Introductory Physics Homework 16
Unit Circle Precalculus Mathematics Homework 2
Unit Circle Help Precalculus Mathematics Homework 14
Work from the bottom of Unit circle to its top in Polar Coordinates Introductory Physics Homework 6
Help with the unit circle please. Calculus & Beyond Homework 7
